A/C Recharge
Old Jun 10, 2008 | 10:46 AM
Gage2502's Avatar
Gage2502
A/C Recharge
Does anyone know if I can charge my A/C myself? Or should I let the dealer do it? About how much should it cost?
It would be for my 2000 Expedition 5.4L.
Thanks ~Gage~
Old Jun 10, 2008 | 10:47 AM
Gage2502's Avatar
Gage2502
O ya I also have rear air.
Thanks guys ~Gage~
Old Jun 10, 2008 | 11:43 AM
gibsonj's Avatar
gibsonj
You really need a manifold gauge to do it properly--need to be able to read both the low side and high side pressure to measure what's going on with your system.
That said, I know that lots of folks buy a recharge kit and do it blind. Probably, that's no worse than what folks do for $29.95 at quick oil change places, when you think about it.
Old Jun 10, 2008 | 12:07 PM
sbclemens's Avatar
sbclemens
If you don't have the proper gauges, then you should take it to the dealer or a shop that specializes in A/C work.
Old Jun 10, 2008 | 12:54 PM
alloro's Avatar
alloro
Better yet, buy the gauges and do it yourself. It will be cheaper and you'll have the gauges for next time.
Old Jun 10, 2008 | 01:35 PM
sbclemens's Avatar
sbclemens
Without the experience and knowledge of servicing A/C systems, you can cause a lot more problems than you're attempting to solve. You can get it serviced at a reputable repair shop for the cost of quality gauges.
Old Jun 26, 2008 | 12:42 PM
Gage2502's Avatar
Gage2502
Thanks guys for the info, I think I will leave this to the dealer to do.
~Gage~
Old Jun 26, 2008 | 01:23 PM
2000Expy's Avatar
2000Expy
See if your dealer has a special first.
Old Jun 26, 2008 | 01:59 PM
cbradford's Avatar
cbradford
I do refrigeration service for a living and you will need, a vac. pump to remove air and noncondensables , a manifold gauge set to connect to low & high side to pull vac and add refrigerant and dry nitrogen to pressure test and leak check ( do not use compressed air) and this all could run several hundred bucks. Now to just add refrigerant you can buy a low pressure gauge with can connection and R134 at auto parts store such as Pep Boys or Auto Zone, Advanced Auto, NAPA.
When I had a problem with my 97 Expy just last year I topped off refrigerant and 3 days later didn't cool, after pressure testing with N2 used a pipe to listen to shaft seal on compressor and could hear leak( Hissing ) and had to replace compressor with clutch that I purchased form Ford about $200 and installed in about 3 hrs and I could only guess how much a Dealer would charge ( arm and leg )
Old Jun 27, 2008 | 08:52 AM
Frat-man-du's Avatar
Frat-man-du
Just did my 03' last night. You really should have te proper equipment to evac the system, pull a vaccum and properly charge it.
I also added tracer dye in case I have a leak. I had not put any in the systems since I have owned it, but it is easy enough to do.
Old Jun 27, 2008 | 08:43 PM
heymrdj's Avatar
heymrdj
Is that just you, or can you get shops to put in dye?
Old Jun 28, 2008 | 07:11 AM
projectSHO89's Avatar
projectSHO89
Either.
You can buy a can of dye charge at any auto parts store.
Steve
Old Jun 30, 2008 | 08:37 AM
Frat-man-du
Yep - cheap around $6.00
Old Jun 30, 2008 | 10:11 AM
heymrdj's Avatar
heymrdj
Originally Posted by projectSHO89
Either.
Steve
I swore I posted a thank you 2 days ago to your post, but apparently it didn't go through. Anyways, thanks for the answer
Old Jul 1, 2008 | 09:12 PM
Gage2502's Avatar
Gage2502
Went to the dealer today to get my brakes done and asked them about my A/C ad they told me its $150 to check it and $2 an oz if I need refrigerant.
~Gage~
