Vent fan speed...doesn't seem right
Old Jun 10, 2008 | 10:34 AM
ghunt's Avatar
ghunt
I had my truck running the other day and I turned on Max A/C and turned the fan speed all the way up to high. But, it wasn't even blowing air out very hard. Is that normal?
Old Jun 10, 2008 | 11:24 AM
Virto's Avatar
Virto
Is it blowing out the defrost vents?
Common problems: plugged up vents, mice nests and leaves and things like that. The blend door that controls which vents get airflow could be broken, or the vac lines the actuate it could have cracks in them and are keeping it from sealing up nice and tight.
The fan blades could be damaged or the motor could be on it's way out, but it's almost always a blockage or a blend door issue.
Old Jun 10, 2008 | 01:18 PM
quicklook2's Avatar
quicklook2
the resistor may have gone bad.
you should have distinct speeds in all settings.
Old Jun 10, 2008 | 03:31 PM
ghunt's Avatar
ghunt
I have distinct speeds...but "High" does not feel as "high" as it should be. It doesn't blow air out nearly as hard as either of my cars do with the fan set on high.
And no it is coming out of the dash vents.
It doesn't sound like there's any crap in the vents (I've had that sort of thing happen on my car before), but I may have to look.
Old Jun 10, 2008 | 04:58 PM
quicklook2's Avatar
quicklook2
check the vacuum line or the door is jammed.
take out the heater core and you will have a clear shot at seeing what is what.
