I currently own a 97 F350 PSD dually CC. It has 280K miles and runs great but it isn't 4wd and I need that as I'm on the farm a lot doing off road work and pulling a trailer in fields etc.
I have found a local 99 F350 PSD CC dually that has 181K miles and they want $10,500 for it. What are the main things I should ask about and/or look for with the 99 model? It has 6 new tires filled with Nitrogen and new brakes all around. Also, new water pump. I've done quite a bit of work on my 97 engine but have never even seen a 99 PSD engine. Are they very similar? It is an automatic (wish it weren't) and I assume the original transmission coolers were crap like the 97s. I replaced my 97 cooler with a much bigger one, the biggest I could find that was made for large RVs. I really like my 97 but I really need 4WD.
I have the early 99- they were made before 12/98- it has a smaller turbo, but with my DP tuner you really can't tell! There are a list of subtle differences aside from that, but I'd never say I'm not happy with my truck. ALSO- the 99's have an external tranny cooler, but it kinda SUCKS- I swapped it out for a 6.0 tranny cooler and she stays under 180*. Plus a dually can handle loads a bit easier, in that you won't really have any trailer sway at highway speeds, and if you blow a tire (I had a 10mm wrench give me the only flat I've had in my life) you can still keep going a ways SLOWLY if you need to, where as a single RW truck you're done till you change the tire.
