Trans Hose ?? Goodyear ???
Old Jun 8, 2008 | 04:24 PM
brnab1's Avatar
brnab1
Looking at a friends axillary trans cooler on his psd this morning the hose says goodyear heater hose ???? Does anyone know if this is an acceptable hose 4 this ?? It was on the truck when he bought it and he drives alot so if its something he should change he wants 2 do it !!!!
Old Jun 8, 2008 | 11:23 PM
SpringerPop's Avatar
SpringerPop
Short answer, NO!!!
Very specific hose for ATF. I bought some when I added my in-line spin-on. Says "transmission" right on it if I recall.
Should say something like SAE J1532. It's a higher-temp nitrile (I think) hose.
It comes in different inside diameters, so he needs to know what size when he goes to buy it.
It's a good idea to get some stainless-steel screw-type fuel line hose clamps and double-clamp (use two side-by-side) at each connection.
Water-rated hose will get VERY soft, very soon!
Your friend bought his truck from someone who didn't do his homework, at least not ALL of it!!
Pop
Old Jun 9, 2008 | 01:10 AM
rbaker6336's Avatar
rbaker6336
Originally Posted by SpringerPop
Short answer, NO!!!
You are correct
A special hose for circulating transmission fluid at high temperatures. The tube and cover are designed to meet OEM / SAE J1532 requirements. Features a polyester reinforcement for high burst protection. Will withstand fluid temperatures up to 257 degrees F and is resistant to fuel, ozone, oil, grease and heat aging.
Old Jun 9, 2008 | 11:33 AM
SolidGround's Avatar
SolidGround
Said hose should be able to hold 250 psi aswell... but then again, alot of Brian's stuff is overkill.
Old Jun 9, 2008 | 11:39 PM
rbaker6336's Avatar
rbaker6336
would nrver have thought but the hose is bout impossible to find where I am
