Sea Foam in brake booster line?
Sorry, it was rude of me to laugh like that, I'm just really opinionated about this subject. I've been on record in many of these 'seafoam' posts as not agreeing at all with putting it directly into the crankcase (or even into the brake booster.) I've seen many people - including people claiming to have an explaination for why it is 'safe' - but having been an engineer for 35 years, and knowing many triboligists (oil and lubrication engineers) and chemists, there is no way that any of us would agree that diluting your crankcase oil for any reason - and then running your engine with it - makes any sense to us. If you want to take a risk at potentially ruining internal bearings, it would be easier to just drain the oil and not fill it back up and then run the engine - same principle. I don't mean to be disrespectul to those who feel comfortable doing this procedure; go ahead and run it in your engine. Me: I only use it in the gas tank. That's it. Again, sorry for laughing, I just can't imagine why people believe that this helps your engine in the long run. More power to those that do.
Nobody is recommending that you leave the stuff in your engine for a extended period of time, but it does clean out your motor. My Expy always runs better after a SeaFoam treatment. As long as you change your oil shortly after adding it to your crankcase, your motor will be fine.
I buy Seafoam by the gallon. It's cheaper that way. If you add Seafoam to a vacuum line(BB) you not adding it to the crankcase(not that there's anything wrong with that). The vacuum line leads to the intake which ends up in the combustion chamber. The more carbon build up the more it will smoke. If you do add Seafoam to you crankcase do it before a pending oil change so it is flushed out with the old motor oil. If you do periodic Seafoam flushes from the time an engine is new the carbon buildup will be minimal. This is especially helpful on 2 stroke engine which burn oil with the fuel so they are prone to carbon buildup especially at the ring lands.
Do you know how the basic 4 stroke cycle works? Do you know how this type of brake booster works? It would probably be a good idea if you could answer these questions BEFORE you start adding Seafoam to your engine(not that it's a bad idea) just because you read it will help it run better. You betray your experience levely by the type of questions you ask.
Ginzu, don't sweat eallenboggs, some people would just rather be a$$es than help people.
Basically, the brake booster line is attached to the engine manifold and uses the vacuum of the engine to charge the brake booster using a one way valve (it's the little black thing at the end of the line on the right side of the circle in the picture above). So if you disconnect the line from the one way valve, with the engine running, it will be sucking air through that line. You use this vacuum to suck the sea foam into the intake manifold where it's distributed to the cylinders.
It's pretty similar to pouring it into the throttle body, but easier to do this way.
#28
Use a funnel and add half a can as quickly as possible to the vacuum line without stalling the engine. Turn off the engine and let it sit for about half an hour. Add the rest of the can to either your fuel tank or crankcase (only if you're going to be changing the oil very soon). Then fire up the engine and drive like a maniac. You may experience a huge black cloud coming from the exhaust so its best to do this on a windy day or at night.
