Brake problems
Old Jun 8, 2008 | 01:41 PM
78bigunns's Avatar
78bigunns
Brake problems
96' F350 5.8L
Was coming home yesterday, and one of the times I hit the pedal it dropped almost to the floor.
I pumped it and it came up.
It did this over and over, it will drop on the first press, and then pump up.
Fluid level is great, no leaks anywhere, vaccum to booster is excellant.
Could the booster itself me shot? Looks original, 150k on the ticker.
Thanks
Blair
Old Jun 8, 2008 | 01:58 PM
88n94's Avatar
88n94
It's most likely your master cylinder. It has 2 boots, one for the front brakes and one for the rear brakes, fluid is going past the first boot allowing the pedal to drop with no external leaks. I've experienced this a few times.
Old Jun 8, 2008 | 02:00 PM
Lazy K's Avatar
Lazy K
The first thing I would do is to pull both rear drums to see that everything is OK. If rear shoes, parking brake linkage, etc. is all OK I would suspect the master cylinder. It is very unlikely to be the booster. When these fail the pedal usually goes hard.
Old Jun 8, 2008 | 02:21 PM
78bigunns's Avatar
78bigunns
OK, at least I know where to look.
FWIW, I had the rea drums apart about 2 months ago and everything looked great.
I'll inpsect again and report back this week.
Thanks
Old Jul 6, 2008 | 01:48 PM
78bigunns's Avatar
78bigunns
Update,
Checked the rears, all good there.
Although one wheel cylinder has the bleeder broke off. No it wasn't me.
Picked up a master, did the full bench and then truck bleed, works great.
Replaced a hard line also from the master to the front split union.
Thanks very much for the help.
78bigunns
Jun 8, 2011 08:28 AM
78bigunns
Mar 19, 2007 01:19 PM
78bigunns
Oil & Lubrication
19
Nov 8, 2006 06:42 PM
78bigunns
30
Dec 27, 2003 08:15 AM
