how to touch up scratch
Old Jun 8, 2008 | 12:13 PM
hatchet's Avatar
hatchet
my truck has a small scratch on the hood near the windsheild its not very wide its about a half inch long and as wide as a pen drawing a straight line.would would be the best way for me to touch it up I dont wanna sand anything and its so small I dont think it needs to be.
Old Jun 8, 2008 | 01:19 PM
just-n-time's Avatar
just-n-time
Wink scratch cover up
hatchet, the market has several scratch removal items scratch Doctor and renusit and others you can try. I have tried them on my wifes Mercedes after some nut placed a long key mark on her roof, I will tell you how I ended up doing the job. First I had to determine if it was clear coated, after that I used 800 grit wet and cut it into finger strips so as to only rub just the line and small area around it then work slowly wiping it frequently to make sure I did not go to deep, stay out of the paint if it has any flake in it. after I sanded the area I borrowed a air brush from my cousin, mixed the clear coat and shot a peace of old metal to try the paint gun I had never used before, then I sprayed the area just enough to be above the original area, after it sits for half to an hour you Begin the wet sanding 1000, 1500, 2000 grit and again just finger width, after that the 3M polishing compound it should look like class. JNT
Old Jun 12, 2008 | 05:08 PM
FordxFour's Avatar
FordxFour
What I do is go get the touch-up paint and clear coat in the small bottles with the brush. Don't use the brush. Get a round toothpick and barely dip the point into the paint, then lightly fill in the scratch with as many thin coats as necessary, allowing paint to dry between coats. Then I apply 2 coats of clear on top, also with a toothpick. About a week later I use a light polish by hand over the area. Most times can't even find the scratch when you're finished. Probably not the correct way, but it works for me. Hope this helps.
Old Jun 12, 2008 | 09:51 PM
hatchet's Avatar
hatchet
Thanks but my truck is a 95 and they dont make the touch up paint for it anymore I checked.where do you get clear coat in little bottles anyway?
Old Jun 12, 2008 | 10:02 PM
FordxFour's Avatar
FordxFour
hatchet, I get the touch-up clear at AutoZone, PepBoys had it the last time I was there.
dbossman
Bed Covers, Tonneau covers, Toppers/Canopies & Bed liners
24
Oct 13, 2012 11:50 PM
curt9999
Appearance & Dress-Up
Mar 18, 2009 02:53 PM
shizats
Apr 1, 2006 07:41 AM
AllenB
Paint & Bodywork
Nov 7, 2005 10:24 PM
Syro
2004 - 2008 F150
Jun 3, 2004 06:41 PM
