low range frustration!
Old Jun 7, 2008 | 11:04 AM
camccardell's Avatar
camccardell
Cool low range frustration!
Ok, I have read as many posts as I can, and I am still without an answer.
I can not switch into low range.
Push button 4x4 works just fine though. I tapped the ol motor with a hammer as a friend suggested, and killed it. I pulled it apart and it looked like a grenade went off in it. I whipped out $100 bucks and bought a new one.
The new one, will switch into 4x4 HI like the old one, but still no 4 Low.
I have looked for the 4x4 control module mentioned in other posts, but cannot find it. It might be there, but I ain't seeing it. I've removed the glove compartment and there are many modules, but no luck on the 4x4 module, at least I think so.
I have tried putting it in neutral and depressing the brake before I push the low button. Still nothing. No clicking, and with the shift motor off it doesn't rotate. It does rotate when I shift it to 4 hi though. I can rotate the shaft on the transfer case with a pair of pliers easlily however. And yes it does go into 4 lo. I was able to shift into 4 low when I purchased this truck, but now it will not do it for some reason.
Please shed some light on this!
Chris
Old Jun 7, 2008 | 01:18 PM
camccardell
I've found the transfer case control module. The light will not light up at all. When I pluged the wires back in, nothing happened. I cannot even go into 4 HI now.
I dismantled the box and I think I found the problem. Does anyone know where I can get a replacement? The dealership cannot get one and the parts places don't know what I am talking about.
Old Jun 7, 2008 | 01:26 PM
camccardell
here are some pics
Old Jun 7, 2008 | 09:59 PM
lostin90s's Avatar
lostin90s
Wreckers. Is were I get them . I have a few somewhere I take truck apart they worked so I kept them .. I'll look .
