Sponsored by: Real Truck
Awsome Group
Old Jun 7, 2008 | 12:17 AM
rcdriver11's Avatar
rcdriver11
Awsome Group
You guys are awsome. I spent the day in the garage with all the replies from this forum. Everyone I used worked out great. I now have 4x4, Airbag light is off, tomorrow I'm going to try the power lock fix. Thanks Everyone. One more thing, any suggestions on finding vacuum leak for auto lock hubs. I'm not very good at diagnostics. Can fix anything just can't figure out what needs to be fixed.
Old Jun 7, 2008 | 05:36 AM
ron's power stroke's Avatar
ron's power stroke
most common place to start is at the wheels and work your way back to the pump...turn key on so the vac pump can be heard but not start the truck..listen for air...or you can use a air hose and blow into the lines and listen for leaks...use low air PSI..dont want to blow the seals in the hubs...
Old Jun 7, 2008 | 10:00 AM
krewat's Avatar
krewat
FTE Leadership Emeritus
One thing that'll drive you nuts with the vacuum ESOF hubs is the solenoid itself.
You can get a vacuum leak at the solenoid which is not attributable to the vacuum lines, hubs, seals, etc.
Good luck with it...
Also, when you say "vacuum leak" do you mean the heater goes to defrost when you hit the switch, or do the auto hubs just not work?
Old Jun 7, 2008 | 01:03 PM
rcdriver11's Avatar
rcdriver11
I tried the heater idea and didn't notice it going to dfrost. The auto hubs just don't work. They lock in manually but not auto.
Also where is the solenoid located.
