223 distributor
Old Jun 6, 2008 | 09:30 PM
F100racer08's Avatar
F100racer08
223 distributor
I need a distributor for the 223 in my '60 f250. What other vehicles/engines used the same one if any?
Figured I could just get at a junkyard since I will be there looking for an intake anyway.
Old Jun 6, 2008 | 10:01 PM
frigerator's Avatar
frigerator
I'm not sure if other dist. are interchangeable. I hope that you have a good junkyard for old parts. Out here in Ore. if you can find it get ready to empty your pockets. 4 yrs ago I found an intake and they wanted 100.00 If you can find a donor truck, that would be the way to go. That is if you need a few other parts. Good luck and fun adventures.
Old Jun 6, 2008 | 11:20 PM
sandhillmike's Avatar
sandhillmike
Napa has them for about $30 - $40, why fool around with used junk?
Old Jun 7, 2008 | 06:35 PM
Col Flashman's Avatar
Col Flashman
To my knowledge there aren't any that will interchange, go to NAPA & purchase a New One & I've an Intake, contact me.
Old Jun 8, 2008 | 04:18 PM
angus's Avatar
angus
There's rumours you can adapt a newfangled distributor off a 300; it requires some machining to change the gear. See the fordsix.com forums.
Old Jun 8, 2008 | 08:31 PM
F100racer08
I'll just by one new at nappa. Also I have a lead on an intake, going to check it out tomorrow. I'm trying to get it running as cheaply as possible and then later down the road when everything else is fixed up I plan to swap in a V8, so I don't plan on spending any real money on this engine.
