Couple random questions
Old Jun 5, 2008 | 04:20 PM
neoxaero's Avatar
neoxaero
First off -- i've got an 02 F350 super crew w/ 7.3
The rear part of the overhead console is broked (was broken when i got the truck) i assume its for a garage door opener or something along those lines.
Can I buy the little flap part that opens by its self or is it sold as a single item??
I'm looking for an exhaust for the truck, what size/brand should I be looking at? -- I'm all about performance, but i also would like for it to be obnoxiously loud (outside the truck)
Intake, what brand/setup should I look into? -- noise doesn't bother me..
BOV... I've seen quite a bit of talk about surging, and knowing how bad this is for gassers, its got to have the same effect on a diesel (bad for turbo) - are there any cost effective BOVs for these trucks? A quick google search yielded one BOV that was around $800.. seems a bit excessive to me?
I see an insane amount of abbreviations used on the forum and have absolutely no idea what 95% of them mean. Is there a comprehensive list of common abbreviations used in this forum? (if not, maybe someone should start a thread)
Old Jun 5, 2008 | 04:25 PM
megawatt00's Avatar
megawatt00
Welcome to FTE! A lot of your questions can be answered here: Powerstroke Help Network
Just look under the mods page.
The best intake is the 6637.
Others will chime in with a ton of info for you!!
Old Jun 5, 2008 | 04:30 PM
zx250's Avatar
zx250
Of the next Riffraff East
Have a look at the sticky thread at the top of this forum, that and the one Jim gave you will either answer your questions or give you more. We all have differant ideas on what is best, read up and then check back, we will be glad to help.
Old Jun 5, 2008 | 04:33 PM
miller_feed's Avatar
miller_feed
Hook it, I'll pull it.
Welcome to FTE.
1. This is what I run, the 409 SS. click me Go 4 or 5", but you don't need 5" unless you plan on over 500 hp.
2. Like Jim said. 6637. Here is a pic of mine with Pete's filter cover.
4. If you get surge with a chip, either get the WW or ATS housing.
5. There is a write up on this, but will take me a few to find it.
Good luck.
jhand124's Avatar
jhand124
Welcome to FTE
2. 4" exhaust MBRP is pretty nice, I have 4" Aluminized from Summit Racing
3. 6637 is the most cost effective and works well I here, I have AFE Stage II with the pg7 filter.
4. BOV?
5. We are insane about the abbreviations.
Mods and maintenance in the above post is a good place to start.
Old Jun 5, 2008 | 04:37 PM
Ponyboychris's Avatar
Ponyboychris
Abbreviation help:
https://www.ford-trucks.com/forums/1...finitions.html
Old Jun 5, 2008 | 04:56 PM
SpringerPop's Avatar
SpringerPop
These diesels don't use a throttle plate, and therefore don't have a Blow Off Valve (BOV).
Pop
Old Jun 5, 2008 | 05:47 PM
neoxaero's Avatar
neoxaero
Pop
the one that i saw released pressure based on TPS sensor input (would release for 3-5sec then close back up) long enough to relieve the pressure and not grenade a turbo
maybe the one I came across is the only one on the market?
Old Jun 5, 2008 | 05:54 PM
mongo75's Avatar
mongo75
I've never heard of a BOV on a PSD. Trust me, these things don't need one- you'll blow off a IC tube before anything else.
Old Jun 5, 2008 | 06:00 PM
SolidGround's Avatar
SolidGround
I have, between the little turbo and the big one...
Old Jun 5, 2008 | 06:03 PM
PowerstrokeJunkie's Avatar
PowerstrokeJunkie
Ha, shut up Jet! Quit rubbing it in... Two turbos on the new engine? you didnt have compounds on that 7.3, a 42r right?
The engine continues to spin over and over when you let out of the throttle, so most of the air goes into the engine as normal, just no fuel to ignite with it.
