Sponsored by: Kumho
Brake Booster
Old Jun 5, 2008 | 12:32 AM
Cowboy34's Avatar
Cowboy34
Question Brake Booster
it is on a truck i have and i need to know how i can check it and see if it is still good or not,,is there a way to check a booster to see if it is any good or not
Old Jun 5, 2008 | 01:07 PM
ynevada's Avatar
ynevada
with the truck OFF. pump the pedal a few times, to drain the vacuum.
wait 30 sec.
with ur foot ON the pedal, start the truck.
does the pedal drop...ever so slightly? 1/4"- 1/2"?
if so, then likely the booster is working.
what problems are you having?
Old Jun 5, 2008 | 08:43 PM
Cowboy34's Avatar
Cowboy34
i forgot to add that the truck i bought does not run it had a carb fire
Old Jun 5, 2008 | 09:56 PM
Sycostang67's Avatar
Sycostang67
Then what do you need brakes for?
I'll assume your planning on taking parts from this truck for another one. The only ways I know to check them are with a running engine as well. If the pedal remains hard with the engine running or if you hear a vacumn leak, then it's bad. I suppose there may be some way you could hook it to another vacumn source to check it.
