1964 steering box rebuild
Old Jun 4, 2008 | 09:34 PM
Voodoo66's Avatar
Voodoo66
Does anyone have instructions or know how to remove a steering gear box from a 1964 F100? also does anyone know what is usually replaced during a rebuild. Reason for rebuild is i have adjusted the screw all the way in and can still turn the steering wheel a little less than a quarter of a turn before the wheels turn. any help would be greatly appreciated.
Old Jun 4, 2008 | 10:52 PM
drof46's Avatar
drof46
Another option is getting the power steering kit they came out with. I may be wrong but I think it eliminates your current gear box and replaces with the a rack and pinion system.
Old Jun 5, 2008 | 05:32 AM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
1961/64 F100/250 2WD steering gearbox parts
1964 F100/250 2WD (same as 1961/63 2WD)
The only new parts available (from NAPA) are the seal and gasket, the one sector shaft bushing, and the two bearings and races on the steering shaft.
2) C2AZ-3571-A .. Steering Shaft Bearing / 2) C2AZ-3552-A .. Steering Shaft Race / B8A-3576-A .. Sector Shaft Bushing / C7OZ-3591-A .. Sector Shaft Seal / C3AZ-3581-A .. Gasket.
NAPA can cross these Ford part numbers over to the brands they sell. The two steering shaft bearings/races, the seal and gasket are the same as 1965/66 Mustang (!) uses.
When one buys a "rebuilt" gearbox, these are the only parts that have been replaced, because the steering shaft worm / the sector shaft have been obsolete for over 25 years.
In an internet search, I found eleven NOS (new,old stock) steering shaft worms, and two NOS sector shafts.
C3TZ3575G .. Sector Shaft
greensalescompany.com has one.
Red Taylor Ford in Corning AR has one.
C1TZ3524A .. Shaft & Worm
greensalescompany.com has 10 / 800-543-4959
Bowman Sales & Service in Bowman ND has one.
JOD F100
New Member Introductions
May 24, 2016 02:27 PM
JOD F100
May 23, 2016 07:00 AM
flamesoldier
Apr 3, 2013 10:20 PM
pwstark
Jan 26, 2013 12:16 PM
64Guy
Feb 12, 2011 10:06 AM
