Crane Rocker Conversion?
Old Jun 4, 2008 | 03:20 PM
TheNomad's Avatar
TheNomad
Hello every I was going to ask to see if any one has used these or do you know that if I could use this and keep my stock rockers or do I have to get new ones? Is there really more then just 'Dropping them in" what are your thoughts on these?? Thanks every one =)
Crane Cams Ford Drop-In Roller Rocker Conversion - JEGS
Old Jun 4, 2008 | 03:28 PM
jjstanza's Avatar
jjstanza
Why not go with 1.7 rockers instead. Crane 44746-16 - Crane Cams Energizer Aluminum Rockers - JEGS
Get more lift and cheaper too!!
Old Jun 4, 2008 | 03:34 PM
TheNomad's Avatar
TheNomad
Hey that sounds really much better! What about valve lift? would I have pull off the head and check valve clearance?? or is this pretty much a straight blot on mod? Or would it just be better to talk to some one at jegs but I like to ask people who have installed and used them in the real world I'E drive way & street. Thanks man =)
Old Jun 4, 2008 | 04:16 PM
Conanski's Avatar
Conanski
What cam is in the motor, and what motor is this? If you have a stock motor with a stock cam then there's absolutely no concern about valve clearance.
Old Jun 4, 2008 | 05:26 PM
TheNomad's Avatar
TheNomad
It's a 302 i'm going to be upgrading to a new cam here soon .. When I talked to the guy at jegs this was some time ago but he highly recommended this
Lunati 61001LK - Lunati Voodoo Hydraulic Camshafts - JEGS
As to what cam is in the motor now I have no clue the guy who built the engine really worked a number on me the cam thats in the engine is the same one that was in it when I brought the truck.. So I have no idea.
