Valve Lash Clearance Specs?
Old Jun 4, 2008 | 01:42 PM
jwiegele's Avatar
jwiegele
Trailering
Can anyone help me? I need to know what to set the Valve Lash at for my 1992 F350 7.3L IDI? Thanks!
Joe
Old Jun 4, 2008 | 03:03 PM
jwiegele's Avatar
jwiegele
Trailering
maybe not...
are hydraulic lifters even adjustable? I'm thinking they are not adjustable.
Old Jun 4, 2008 | 04:44 PM
catfish101's Avatar
catfish101
You can adjust hydraulic lifters but you have to shim under the rocker to do it.
We used to do that with older Ford gas motors. We use to set the cam on the inner base circle and shim them till you got .010" drop on the push tube into the lifter. That would help keep the lifter from floating when at a high rmp.
Old Jun 4, 2008 | 09:55 PM
jwiegele's Avatar
jwiegele
Trailering
Thanks Catfish101! I appreciate your experience.
Old Jun 4, 2008 | 11:01 PM
Dave Sponaugle's Avatar
Dave Sponaugle
You should not have to worry about valve lash.
3300 RPM is not exactly high RPM.
78 & 87 Super Cab
Apr 27, 2015 06:09 PM
C-700
May 28, 2014 10:32 PM
crazy96863
20
May 25, 2013 12:28 AM
Randyb12
Apr 1, 2004 10:23 AM
sanand
1983 - 2012 Ranger & B-Series
Sep 18, 2002 11:37 AM
