Hard to Start
Old Jun 3, 2008 | 10:12 AM
BenC350's Avatar
BenC350
Hard to Start
I have a 2006 F-250 that is really hard to start. It takes about 4-6 seconds everytime I go to start it. I have brought it to the local Ford dealer 3 times now and they still can't figure out what is wrong with it. They said that the batteries were weak but I changes both of them and still the same. Has anyone else heard of this or had this problem?
Old Jun 3, 2008 | 11:34 AM
Lou Braun's Avatar
Lou Braun
Our diesel engines need to crank long enough for the high pressure oil pump to develop the 500 psi needed to fire the injectors. A 4 to 6 second cranking time does not sound out of line.
Use of some aftermarket oil filters will increase crank time because the filter housing drains down when the engine is shut down. If non-OEM filters were used in your last oil change, I would start there. Swapping out oil filters is very simple on our trucks and is worth doing if the filter is suspect.
Lou Braun
Old Jun 3, 2008 | 11:44 AM
BenC350's Avatar
BenC350
Thanks for the reply. I always have the dealer change the oil and they use factory replacement parts. They had to change the high pressure oil pump on the truck and also some type of screen on the turbo. I work with a bunch of guys here that all have diesel trucks and mine is the only one that spins over for that long.
Old Jun 3, 2008 | 12:46 PM
brickie's Avatar
brickie
Try load testing your batteries.If one is low it can cause long crank times.If one is bad replace both.
Ar. Hillbilly
18
Nov 16, 2016 08:16 PM
rmgraw351
Nov 15, 2015 06:49 PM
trevorrules
40
Apr 9, 2015 07:55 AM
fancyvern
Mar 4, 2014 05:27 PM
n.o.yat
Oct 28, 2008 08:44 AM
