broken leaf spring
Old Jun 2, 2008 | 07:14 PM
someday's Avatar
someday
broken leaf spring
when i was doing the brakes on my 89 e250 i noticed a broken leaf and wierd tire wear on the back tires probably from dog tracking...anyhow i have found e250 and e350 springs from the junkyard...the spring codes are different but they look exactly the same and number of leaves (6)...the spring code for the e250 (n) has a rear capacity of 5300 while the e350 (j) is 6084...i am thinking because the e350 has a full floating axle and bigger brakes the capacity is more but the springs are the same...does anyone know if this is the case?
Old Jun 3, 2008 | 06:46 PM
mhg's Avatar
mhg
looks are decieving
are the part #s the same
if not then they are diff. springs
Old Jun 3, 2008 | 07:16 PM
someday's Avatar
someday
i just checked at the dealer and the part numbers are different
Old Jun 3, 2008 | 09:59 PM
someday's Avatar
someday
i know early superduty pickups used the same springs between the f250 and f350 but used a block between the axle and spring to give it some lift...turns out both sides had broken leafs
