Spongy Brakes
Old Jun 2, 2008 | 05:21 PM
mbt3000's Avatar
mbt3000
Spongy Brakes
I have a 2005 Mazda B-Series with 30,000 miles. I recently had new front brake pads put on. I can't tell any difference. The pedal is still as spongy as before. What's wrong here?
Old Jun 2, 2008 | 05:34 PM
bazzman1953's Avatar
bazzman1953
Sounds like air in the lines to me.
2 questions...
1- when did the brake pedal start to feel 'spongy'?
2- isn't your truck still under warantee?
Old Jun 2, 2008 | 05:37 PM
mbt3000's Avatar
mbt3000
It's been spongy for a long while.
It's not under warranty.
Old Jun 2, 2008 | 08:36 PM
bazzman1953
When was the last time your rear brakes were adjusted? 30,000mi. is too soon for the front brake pads to be replaced unless the rear brakes are out of adjustment.
Old Jun 3, 2008 | 12:09 PM
michigan66's Avatar
michigan66
Welcome to FTE. The are lots of folks that can provide good help for you.
I'd pull a rear brake drum to check the lining. If the wear is normal or less, put the drum back on and adjust the rear brakes. The easy way to do it is by backing up and apply the brakes sharply (hard). do this several times and see if your pedal firm up. If no, you should have the brakes bled. You could have gotten air in the lines as the fronts were done.
Old Jun 4, 2008 | 08:13 AM
pawpaw's Avatar
pawpaw
A spongy/soft brake pedal is typically a sign of air in the system, but may also be caused by dryrotted, weak/flexing rubber hoses, or maybe a master or wheel cylinder piston sealing problem.
Did/Do you have any brake fluid leakage/wetness signs, anywhere along the brake system?????
Has the master cylinder fluid level been dopping, such that you've had to regularly add fluid????
Old Jun 7, 2008 | 07:19 PM
Peter94's Avatar
Peter94
My bet is a clean and adjust on the rear shoes is needed. Dont count on the self adjusters, remove the drum and adjust them yourself.
mntneer
1997 - 2003 F150
Oct 26, 2012 01:52 PM
EliteScapes
Apr 18, 2011 11:43 PM
Flaw
1997 - 2003 F150
Apr 19, 2005 06:27 PM
parrfict
1997 - 2003 F150
16
Nov 30, 2004 11:58 AM
Blaine Schulte
18
Sep 19, 2003 11:25 AM
