Oasis ?
Old Jun 2, 2008 | 02:19 PM
carrnut's Avatar
carrnut
Oasis ?
I have seen people refer to an OASIS report before. What is it?
Old Jun 2, 2008 | 03:11 PM
Paul T's Avatar
Paul T
From what I have read, an Oasis Report is Fords history of your vehicle. You can obtain one by contacting your local Ford service department and asking for one. You just have to furnish your VIN. I have not found out yet if you are charged for this service or not. Sometimes, if you are lucky, a fellow FTE member might be able to obtain one for you.
Old Jun 2, 2008 | 03:16 PM
FordTruckGirl77's Avatar
FordTruckGirl77
A dealer cant charge for that, from what I remember. A service writer should be able to give you one, but if you do not own the vehicle I dont know if they will do it. Its a history of the vehicle and recalls on it would be on there as well. I used to run them all the time and they are very simple to do. I dont have access to them now or I would help out.
Old Jun 3, 2008 | 07:15 PM
Mike E.'s Avatar
Mike E.
Good in Canada?
Probably a dumb question, but will there be Oasis reports on Canadian vehicles?
Just asking 'cause I have an '00 Ex Limited V-10 or an '01 F250 V-10 crew in my sights if/when my Ram 1500 sells, and seeing how folks here seem so obliging in looking up reports for others I thought I'd inquire.
Thanks,
Mike E. - up in the 'burbs of Vancouver.
Old Jun 4, 2008 | 08:20 AM
BIGKEN's Avatar
BIGKEN
Mike...the reports should be good north of the border.
Old Jun 4, 2008 | 05:26 PM
FordTruckGirl77
Im going to jump in here and ask for another Oasis. I know Ken you said Oasis is down right now so I know you cant do it right away. I came across this Excursion today and Im sort of interested... They dont list the miles though they say Low miles...
vin # 1FMSU43PX4EA29863
Here is the link price is good!!!
Cars For Sale: Car Details - AutoTrader.com
Old Jun 5, 2008 | 01:07 PM
BIGKEN's Avatar
BIGKEN
TIFFANY...IN MY OPINION...RUN FROM THIS ONE!!!
DOB...8/13/03
ISD...10/14/03
10/9/03 Reprogram all 3 modules
10/13/03 Reinstall wiring harness
9/3/04 EGR Tube clogged
4/13/05 Fuel pump inop due to corrosion inside
7/28/06 Replaced ICP, Turbo, y pipe
10/18/06 Replaced ICP
8/21/07 Replaced rear plate gasket, rear main seal, front crank seal, oil pump "o" ring, oil drain plug gasket
Bkl251988
Oct 14, 2022 10:59 AM
Totally Tuna
Apr 2, 2014 02:13 PM
superhooperduty
Mar 3, 2014 10:05 PM
kips
Jul 5, 2008 08:58 AM
ccfdsuperduty
May 24, 2007 09:46 AM
