Throttle dosent work (sometimes)
Old Jun 2, 2008 | 01:17 PM
mercman86's Avatar
mercman86
A buddy of mine has a 1999 F-350 with about 165K on the 7.3 PSD and this morning he went to accelarate from a stop and when he stepped on the gas, nothing happened except the service engine light came on and then went off right away. He then let off the gas and tried to accelerate again and it worked the second time. This problem happened 3 times this morning on his way to work. I hooked my code reader up to it and it showed no trouble codes and seemed to operate fine. The truck was just at the dealer for them to replace a cam sensor under a recall. Has anyone had somthing similar happen? If so, what was the cause and how can we fix it?
Thanks in advance!
Alex
Old Jun 2, 2008 | 01:57 PM
nlemerise's Avatar
nlemerise
Read this thread:
https://www.ford-trucks.com/forums/7...need-help.html
I'd bet it is the chaffed wires in the steering column or the throttle position sensor.
Old Jun 2, 2008 | 08:28 PM
mercman86's Avatar
mercman86
thanks for pointing me in the right direction!
ill check those wires
Old Jun 2, 2008 | 09:51 PM
big poppa's Avatar
big poppa
Also sometimes the exhaust back pressure valve in the turbo sticks and its slow to go when you pull out. I had that problem one time i pulled out before letting the motor warm up enough and it didn't want to go, like it was starving for fuel. Only happened that one time. Good luck.
Old Jun 3, 2008 | 12:53 PM
mt griz's Avatar
mt griz
I just joined the forum for this same problem.My truck has always been great and them I took it in for the cam sensor recall.A week later it acts like its starving for fuel wanting to die when i put the pedal down in normal driving conditions.I changed the fuel filter but nothing.
Old Jun 3, 2008 | 06:53 PM
big poppa's Avatar
big poppa
Welcome to FTE, others will chime in to help you also. The best thing, if you know somebody that has a code reader, pull some code,s for you. Did you check your air filter? Could be dirty.
Old Jun 4, 2008 | 03:17 PM
mt griz's Avatar
mt griz
Thanks for your reply,I am scanning but it throws no codes,if it was fuel injection pump related would it throw them ?Also mercman86-any update?
Old Jun 4, 2008 | 05:27 PM
HKusp's Avatar
HKusp
What kind of a scan tool are you using? The PSD's aren't OBD II compliant so if you don't have one that is specifically for the ford diesel's it won't read them properly. Sometimes it's the pedal assembly. These trucks don't have a linkage, they are fly by wire. Sometimes the sensor on the pedal goes bad.
Old Jun 4, 2008 | 11:28 PM
Paul Moody's Avatar
Paul Moody
Alex,
I've had the same thing the last week. 1-2 times a day I let off throttle to coast and when I push again, nothing. I let off and push and it works fine until it decideds it wants to play again. Yesterday it did it 3 pushes in a row with a check engine light. It appears the throttle signal is being interupted. I called and talked to the dealer yesterday. They say it sounds to them that the throttle controll sensor mounted at the base of the throttle pedal is going bad. They want $259 for a new one. It comes as one unit with the pedal itself. They say this is not an uncommon situation.
As for me, I'll wait and play around a little first before I spend that money. I unpligged the two wiring harnesses hooked to the sensor and made sure they were clean and blew them out and hooked them back up. No problems today. I'll keep you posted.
Paul
2000 7.3
Old Jun 4, 2008 | 11:47 PM
jhand124's Avatar
jhand124
Originally Posted by Paul Moody
Alex,
Paul
2000 7.3
Paul I am with you here I think you nailed it I would check with direct ford parts to see if they have the TPS cheaper. It is only a sensor I wouldn't think there is a need for the whole Petal to be replaced
Old Jun 5, 2008 | 11:57 AM
HKusp's Avatar
HKusp
I have a link to that assembly on my home computer. I will post it later.
Old Jun 5, 2008 | 12:44 PM
mercman86's Avatar
mercman86
Alex,
Paul
2000 7.3
This is exactly what his truck is doing. Im using a Mac Tools OBDII reader, it should work, right? On thing i noticed when i connected the tool, when i selected the read code function, it killed the motor and wouldn't restart till i unpulgged the reader. He checked the 3 wires comming from the tps and everything seems ok. So the fix looks like a tps...maybe?
Old Jun 5, 2008 | 03:31 PM
VQ2Fast4U's Avatar
VQ2Fast4U
Alex,
X2 for me. I havent had a chance to check it with AE but my first thought when it happend, was I need a new TPS.
Old Jun 5, 2008 | 04:53 PM
santacruzf250's Avatar
santacruzf250
I've had my pedal assembly go out three times on my truck. I had a faulty ECM that was frying pedals. My gas pedal worked randomly. It's about a $100 part at the dealership.
