Sponsored by: Innova
New stereo install?
Old Nov 3, 2002 | 11:14 PM
whphel's Avatar
whphel
New stereo install?
I just installed a new Pioneer deh-2300 Cd player in my 86' F-250 and it sounds great; however, now my dashboard light does not turn on. I did go to the installdoctor web sight and did not find any info as to whats missing. I used a wire harrness connector. and there is one wire from the harness labled dimmer but I dont know where to connect it "if that is the problem". Any help or sugestions would be great. Thanks John.
Old Nov 4, 2002 | 04:32 PM
optikal illushun's Avatar
optikal illushun
New stereo install?
dimmer wire is usually orange, is that wire on the harness u got or the on that came with the cd player? most likely u crossed a wire wrong, go back and take a look over it again. sorry i cant be much of a help on this. good luck.
Old Nov 4, 2002 | 06:22 PM
whphel's Avatar
whphel
New stereo install?
Well I got an email from another member here, he thought i might have blown a fuse. I thought I had not but after checking again I had. It seams that when i first hooked up the stereo all worked well untill last night I was going to go to the store truned the thuck on and when I turned on the headlights the stereo truned off. If i turned the heallight off it would work again. Must have had something to do with the two power lines being reversed as you said which cased the fuse to blow. I havent put a new fuse in yet as I checked it on my lunch hour and will replace it tonight but im pretty sure thats the only issue now. I'll let you know if that was the issue once I replace the fuse. Thanks for the reply.
Old Nov 5, 2002 | 10:52 AM
whphel's Avatar
whphel
New stereo install?
It was the fuse . Next time I'll check them first instead of lookng for the prob. some other place.
Old Nov 5, 2002 | 08:20 PM
optikal illushun
New stereo install?
glad to hear :-) , enjoy ur stereo.
Old Nov 5, 2002 | 09:34 PM
optikal illushun
New stereo install?
