Another Rear ABS Question
Old Jun 1, 2008 | 09:14 PM
CaliFordDood's Avatar
CaliFordDood
Hey all...
I'm new to the '87-'96 community.
My girlfriend and I decided that we need a (running) truck, and I was able to scoop up a VERY clean 1987 F150 2WD LONGBED for dirt cheap.
The trucks runs great. It's probably the best deal I've gotten on ANYTHING in the last few years.
Here's the question: I bought the truck with the Rear ABS light steadily on. I've been searching thru this forum, but I can't find the answer I'm looking for.
Apparently, there's supposed to be wires coming out of my brake reservoir...but they're not there. The resevoir DOES have the female connector, but I can't find the male connector anywhere.
1. Would this have anything to do with my ABS issue?
2. Where (what wire loom) are these wires supposed to be coming from?
Thanks in advance for any help you can give me...
Old Jun 2, 2008 | 06:55 AM
purecty's Avatar
purecty
rear abs light
your wires may be loose, they may be just hanging down, its 3 wires with a connector on each one that goes into a plug on master cylinder. mine got loose from the plug somehow. my emergency brake light was on all the time plus my abs light. i kept switching them until the brake light went off when i released the emergency brake. but abs light still stays on. i dont know if they are back right or not. i dont think anyone ever said if it has anything to do with the abs light or not. i do know that a while back w/e i released the parking brake the abs light would go off too. but then it got to where it stayed on all the time. good luck. if you find out let me know too. lol
bill
it will drive you nuts, beleive me
Old Jun 2, 2008 | 12:19 PM
Lazy K's Avatar
Lazy K
Go back a page so to thread by purecty. If you scroll down you will come to a super post by F150xlt giving the RABS wiring diagram. You will have to get that sorted out before you go any further. Unfortunately purecty was not able to get his fixed. However there is a lot of good information in his thread which may help you. Also a lot of guys don`t rate the RABS system and prefer to do without it. It`s your choice.
Old Jun 2, 2008 | 05:02 PM
EPNCSU2006's Avatar
EPNCSU2006
might want to check who started this thread
Old Jun 2, 2008 | 05:19 PM
ArdWrknTrk's Avatar
ArdWrknTrk
pedant
CaliFordDood,
The thread in question is here: https://www.ford-trucks.com/forums/7...7-f-150-a.html
Old Jun 2, 2008 | 06:52 PM
CaliFordDood
3 Master Cylinder Wires
Since those 3 wires are unplugged (still can't find them)...shouldn't my "BRAKE WARNING LIGHT" be lit up?
Old Jun 2, 2008 | 07:10 PM
EPNCSU2006's Avatar
EPNCSU2006
please ignore my first post....I'm an idiot sometimes
Both the brake warning light and the RABS light should turn on when the master cylinder float switch is unplugged.
Old Jun 2, 2008 | 07:47 PM
ArdWrknTrk's Avatar
ArdWrknTrk
pedant
unless someone cut it out of the harness and jumpered it trying to "fix" the problem....
Old Jun 3, 2008 | 03:16 AM
CaliFordDood
Yeah...that's what I'm thinking happened. What colors are the wires you have plugged into your reservoir?
Old Jun 3, 2008 | 05:08 AM
ArdWrknTrk's Avatar
ArdWrknTrk
pedant
2 purple w/ black trace (front and rear) w/ a black wire in the center.
Old Jun 3, 2008 | 06:59 PM
CaliFordDood
ArdWrknTrk, and everybody else...FIXED IT!
Found the wires, cleaned off the contacts...and the Rear ABS light went out. My day is better now.
Still confused on why the brake light wasn't coming on...but it's OK.
BTW...looks like the master cylinder is pretty new...I think the tech (or do-it-yourself guy) lost the wires under the mess of the hood.
Thanks again...
