Belt tensioner?
Old Jun 1, 2008 | 08:54 PM
ghunt's Avatar
ghunt
Belt tensioner?
Still trying to track down the annoying squealing sound on my truck that only happens above 1000 RPM, and I'm thinking it's the belt. I noticed that it's hardly even taut (belt looks fairly new), so I think the belt tensioner may be worn out.
Can I even get a new belt tensioner for this thing? It's got the hydraulic damper on it, and all the ones the parts stores list are not that kind.
Old Jun 1, 2008 | 10:19 PM
catfish101's Avatar
catfish101
I would think you couldn't get the right tensioner for it. If it the belt squealing then you can find that. Run it for a minute or two while it is squealing. Shut it down and feel the pulleys. The one slipping causing the squeal will be hot.
Old Jun 1, 2008 | 10:52 PM
matts156's Avatar
matts156
NAPA carries a correct replacement but it doesn't have the hookup for the dampener. The parts stores and the dealer all carry the open spring design which won't work if you had the closed spring design because there is nothing in the block for the tensioner to load against.
Old Jun 1, 2008 | 11:51 PM
ghunt's Avatar
ghunt
Damn...well that figures. Maybe I could just try some belt dressing then.
Oh, and you have to either have it under a load or rev the engine to get it to squeal...so I dunno if it'd be that easy to find where it's actually coming from. I wouldn't be surprised if it's actually slipping on the alternator, but I can't really tell.
Old Jun 2, 2008 | 12:25 AM
rupejosh's Avatar
rupejosh
i had to replace my belt tensioner in downtown seattle after it decided to explode on me 300 miles from home.and i beleive i got mine from schucks there and the tensioner cost me the same amount as my belt and if you let it go you will have to replace both probably cause the fan will chew the hell out of the belt so if ya want to save some money just replace the tensioner before you have to replace the belt as well.the tensioner is really easy to put on.if ya need some help let me know
Old Jun 2, 2008 | 10:22 AM
ghunt's Avatar
ghunt
But the point is that I can't find the RIGHT tensioner...
Old Jun 2, 2008 | 11:07 AM
jim0936's Avatar
jim0936
Theres a indentation on the back side of the belt tensioner, aluminon at that, have a new iundent welded on your and it will keep the right tention.
Old Jun 2, 2008 | 11:11 AM
jim0936's Avatar
jim0936
Check to see if the indent on the back side of your tensioner is broke off, thats is what was wrong with mine, have a new one welded back on it.
Old Jun 2, 2008 | 07:35 PM
rupejosh's Avatar
rupejosh
a reason you cant find the right one is because its a 94 on my 94 i have to verify a couple times with the parts counter people that im getting the right part because it was also the year they brought out the powerstroke.if you wanna try this tell them its a 93 turbo diesel or non turbo diesel i have had a huge issue with people trying to sell me powerstroke parts.make sure its for the k vin and not the h the h is for powerstroke the k is for the idi's
Old Jun 2, 2008 | 10:44 PM
ghunt's Avatar
ghunt
Ouch.
Well I finally found the dampened tensioner on rockauto.com, listed under a 1990 with a 7.3L. It's $122 for a new one (motorcraft part).
Guess I will try that belt dressing.
Old Jun 2, 2008 | 11:57 PM
rupejosh's Avatar
rupejosh
schucks has them if you have a schucks out thereif not you can order online they are $60.99 here is the linkWhile we find your parts, please enter your ZIP Code at PartsAmerica.com if i can find anymore cheaper ill let ya know but thats the exact one i have.
Old Jun 3, 2008 | 08:28 AM
ghunt's Avatar
ghunt
we don't have schuck's here...and your link just goes to partsamerica.com, they don't even list a tensioner for the older trucks.
Old Jun 3, 2008 | 03:42 PM
1994diesel's Avatar
1994diesel
could it possibly be the ball bearing? mine has one, i replaced my tensioner, but mine was spring loaded, and the new one spun pretty good, and the old one not so well.
Old Jun 3, 2008 | 11:50 PM
rupejosh's Avatar
rupejosh
i just looked it up again try this link CSK Auto, Inc. - Checker Auto Parts, Schuck's Auto Supply, Kragen Auto Parts, and Murray's Discount Auto Stores and click shpping then type in your vehicle info it popped up with mine and i have a 94 idi turbo as well.and i do agree alot of times it is a pain to find parts
Old Jun 4, 2008 | 02:01 PM
ghunt's Avatar
ghunt
That link once again takes me to partsamerica.com (do they supply EVERYBODY?), and they still don't have the correct tensioner.
I may check the bearings but I kinda doubt it.
