Rocker Install
Old Jun 1, 2008 | 07:06 PM
scatgo's Avatar
scatgo
Rocker Install
Don't you have to make sure the camshaft is at it's lowest point when you remove or install a rocker? And do this for each rocker? The manual I just looked at said to make sure you have the index mark in the 11:00 position and thats it. Am I missing something?
Old Jun 1, 2008 | 10:55 PM
BlueMule's Avatar
BlueMule
I don't understand the 11:00 o'clock position either, but that's what the Helms manual says. I've had the pushrods and rockers out 3 times, twice before I knew that the crank was supposed to be at 11:00. I never had any problems either of the 1st two times but figured I'd pushed my luck far enough and did it Fords way the 3rd time. Since then I have talked to a Ford diesel tech who says he never sets the mark and has never had a problem either.
Old Jun 1, 2008 | 11:08 PM
scatgo's Avatar
scatgo
Did you notice valve spring pressure on the bolts that hold down the rockers as you were removing them? And on a install with hydraulic lifters don't you have to put some pressure on them to bleed out the oil from the lifters?
Old Jun 2, 2008 | 01:01 PM
Neal 97 250's Avatar
Neal 97 250
I think 11:00 is where lift is off of ALL rockers. IIRC. I know it is something like that.
Old Jun 2, 2008 | 03:48 PM
scatgo's Avatar
scatgo
Yea, thought it might be something like that but I cant see how all valves can be closed at the same time. And still wondering about bleed down on the tappets.
old farmer
Oct 5, 2014 04:45 PM
jtindale
Jul 20, 2012 10:45 AM
fordboy300
Jun 30, 2012 09:33 PM
8525ford
Jun 16, 2010 01:20 AM
CatFlip
Jul 31, 2006 07:58 AM
