Sponsored by: Auxito
Center Cap Compatability??
Old Jun 1, 2008 | 02:02 AM
that_one_guy's Avatar
that_one_guy
Unhappy Center Cap Compatability??
hey guys, i've got a question about the center caps for the oem steel wheels that look like this:
i own a '99 f-150 ext. cab 4x4 that came with these wheels (pictured above) from factory. now the center cap for these rims look like this:
now the problem is, a co-worker and i swapped rims and tires for our trucks, she drives a '03 f-150 ext. cab 4x4, and when i was installing my old factory rims on her '03, i didn't know that in '00 ford started putting 14mm diameter lug nuts on the '00 and newer f-150s instead of the previous 12mm diameter lug nuts. so basically, although my '99 factory rims fit on her '03, the center caps that came with them were originally made for the '99 model (which has the 12mm lug nuts), and don't fit correctly on the '03 model (which has the 14mm lug nuts).
so i need to know where i can get these center caps (pictured above) that will fit the year '00 and up model f-150s with the 14mm diameter lugs nuts...
please help! i've been looking all over the net, and no one can seem to specify which ones will fit which!
Old Jun 1, 2008 | 05:16 AM
phil6608's Avatar
phil6608
See if you can get a part # off one and then look on this site.
It's all I could find and there's a bunch of different types for 03 F-150
Tasca Auto Group | Your Online Parts Dealer
