Transfer case shifting problem
Old May 31, 2008 | 06:55 PM
Texasplumr's Avatar
Texasplumr
I'm new here, hi! My name is Russ and I live in Austin, Tx.
I'm considering buying an 87 F 250, 4X4, 460CI, 5 speed manual transmission. The truck is clean and low mileage, drives great and best of all, the price is right.
My only problem with it is the transfer case will not shift into neutral or 4L. The four wheel drive works great in 4H and 2H works great as well. The 4X4 was very rarely used in this truck and I'm thinking that it is maybe a linkage problem. At least that is what I'm hoping.
Anybody know of something that could be wrong here that may be more serious that this?
Just thought I'd throw this out for the more knowledgable before I throw away a bunch of money.
Thanks!
Russ Lane
Austin, Tx.
Old May 31, 2008 | 07:13 PM
tjc transport's Avatar
tjc transport
i ain't rite
welcome to FTE, Russ
this is a standard problem with the 4X4 transfer case linkage when it is not used or rarely used.
it can normally be fixed by removing the shifter, disassembling it, cleaning it real good, and lubricating it before reassembly.
i have had to do it on my 88 5 times so far.
Old May 31, 2008 | 07:14 PM
danr1's Avatar
danr1
It's common from what I've seen with them. The shifter never being put in low now and then freezes up, it has to push down to clear the index pin.
That's probably all that's wrong with it but I would get it to shift before buying it. Now if the price is "right" I would take it "as is", small gamble its more than that.
A replacement shifter (if you can't free it up) cost about 100 bucks.
Removing the shifter as a unit to work on it is best, need to carefully open the rubber boots and soak it with penetrating oil. Flip it upside down, work from both ends.
whiskeyrichard
Mar 5, 2022 10:34 AM
jennkent5454
1997 - 2003 F150
Mar 2, 2010 07:12 AM
H1449-6
Nov 26, 2009 01:21 AM
russtay66
New Member Introductions
Feb 21, 2005 09:05 AM
moorefun
Mar 28, 2004 06:49 AM
