Sponsored by: Real Truck
transmission questions
Old May 31, 2008 | 06:45 PM
John M T's Avatar
John M T
Hi all,
a few questions.
99 f350 7.3 c/c dually
I run all synthetic fluids, and have a large tranny cooler, also tranny gauge, and will be towing a 15000 lp trailer
how much HP can the stock tranny take before upgrades? I read 500 hp
how about the stock Torque Converter?
How much does a valve body upgrade help?
with the trailer listed above, will my tranny and t/c be safe?
what upgrades if any do I HAVE to make, or in general should I make?
thanks in advance
John M T
Old May 31, 2008 | 07:24 PM
rbaker6336's Avatar
rbaker6336
don't know who stated 500 Hp but the trans is the weak link in these trucks but should be good a 300 HP
the trailer you list is no problem as long as the trans doesn't overheat
A performance valvebody is a good upgrade at any HP
Old Jun 1, 2008 | 10:38 AM
John M T's Avatar
John M T
Thanks Ray
for responding, the 500 HP tranny rating came from an article in either
8-Lug magazine, or it was Diesel Power mag.
so you think the stock T/Q would be fine, just get a valve body?
can you recommend one?
thanks
John M T
Old Jun 1, 2008 | 10:59 AM
rbaker6336's Avatar
rbaker6336
John Wood or BTS seem tobe the favorites I prefer John Wood
A DP tuner Dp Tuner is good to add with a valve body;the tow tunes make the trans shift better
Factory Tech also makes a good VB
