Carb issues
Old May 31, 2008 | 11:40 AM
mudder460's Avatar
mudder460
Angry Carb issues
Ok, I have been tryin to get my stock motorcraft carb adjusted for MONTHS now. I just can't get it right. It will start up great and idle good but it sputters when you hit the gas. I have the timing set a 8*btdc, I can't remember what I have the air/fuel screw set at, I want to say like 2.5 turns. Can anyone give me a suggestion on what I can do to get it running better. I am tired of messing with it.
Old May 31, 2008 | 12:10 PM
fmc400's Avatar
fmc400
MSEE
With the truck off, open up the air cleaner and look down the throat of the carb. Pull the throttle; you should see a nice even stream of gas shoot across the throttle bore. Check that first.
