Help with transmission oil line to radiator
I found a leak on the radiator of my 1999 f-250 superduty where the upper plastic tank is crimped to the core. I've got 200,000 miles so I think a new radiator is in order. I want to do the job myself, but cannot loosen the transmission oil line closest to the drain **** of the radiator. The other line broke loose easily. I am unable to break the other lline loose using all my strength and a lot of penetrating oil. Any tips on this? The fitting is fairly soft and is beginning to round off. Is it possible that I may have to cut the line and patch in a piece? Anyone else have a problem like this?
Are you using flare nut wrenches to try and take it off? If it still won't go I'd use a very very small amount of heat on it to see if that will loosen it up. I remember mine were a PITA when I had to replace my radiator for the exact same reason. Also the new radiator will come with new adapters for the core so you can destroy them if need be.
Trigger200
1997 - 2003 F150
06-07-2009 05:27 PM
