seafoam
Old May 30, 2008 | 10:58 PM
kupaa's Avatar
kupaa
seafoam
I was reading a post on powerstroke nation that some guys add seafoam in there fuel bowl when changing filters.filled it right up and started the motor.Would any of you do that.Here is the link.any real proof injector cleaners work? - Powerstroke Nation
Old May 30, 2008 | 11:27 PM
randomhero1172's Avatar
randomhero1172
Everything i have read here says stay away from any engine cleaner especially on diesels. Apparently they do not work and actually are not good for the engines. In the negative category the brand seafoam is usually the first name up.
Old May 31, 2008 | 04:58 AM
AustinS's Avatar
AustinS
The only thing I use Seafoam on is my outboard, chainsaws and weedeater. It works great on two-stroke motors, but I wouldn't use it on your truck.
Injectors are a bit pricey. I use BG 244 every third year or so and Diesel Kleen regularly, and in seven years I've not had any injector problems at all.
Buy fuel from stations that move a lot of diesel, every oil change drain the fuel from the water separator, and change your fuel filter at least every 15K, and you should be good to go.
Austin
Old May 31, 2008 | 08:23 AM
F350-6's Avatar
F350-6
It smells like alcohol to me. I'll dump it in a gasser, but I don't like alcohol in a diesel.
PStruwing
Dec 9, 2012 03:02 PM
stephendudra
Jun 27, 2010 09:59 PM
Rebel Ford 95
Aug 20, 2008 10:34 PM
darsacal101
1983 - 2012 Ranger & B-Series
Mar 9, 2008 08:35 AM
makthenif
3.8 & 4.2L V6
Apr 17, 2006 04:40 PM
