Piston choices????
Old May 30, 2008 | 06:48 PM
Machman's Avatar
Machman
Piston choices????
Ok guys, Yes it seems to be beat to death, but there is still no difinitive answer as to what pistons are out there other than custom ross units. Does a true flattop piston exist or is the closest one from a 351 with a smaller wrist pin diameter? My 95 is about to go under the wrench for rings and I would really like to bump the compression up to about 9:1-9.5:1 while I am at it. From what I have researched so far, there is a flattop available only the compression height is not correct. What is the exact cc volume of the chamber? I am thinking total seal gapless rings on whatever piston I can come up with. Any info would be great other than the usual "do a search". I figure someone out there has been down this road before.
Old May 30, 2008 | 09:38 PM
Harte3's Avatar
Harte3
Old May 30, 2008 | 10:42 PM
Machman's Avatar
Machman
Thanks. Slim pickens but it looks like Venolia has a part number for me to request info on. I will call on Monday. How about head combustion chamber volume?
Old May 31, 2008 | 09:12 AM
Harte3's Avatar
Harte3
Those numbers have been posted several times on the FSP 240/300 Forum. Check in there and do a search...piston stuff too.
Old May 31, 2008 | 05:37 PM
Machman's Avatar
Machman
What is FSP? Nevermind,got it.
Old Jun 5, 2008 | 07:48 PM
Machman's Avatar
Machman
Ok, so far what I found was a piston from a 351w with an early 300 rod with a .912 wrist pin should work. The compression height and the bore is the same only the wrist pin is smaller. I still need to check on the early rod specs. This combo should work. I am going to check with an engine builder. I will keep all interested parties posted.
Old Jun 6, 2008 | 10:06 AM
Harte3's Avatar
Harte3
IIRC the stock 300 head cc's at 76 and a 240 headat 69.
Colt.S.
Sep 21, 2015 02:23 PM
nealro
16
May 20, 2015 09:31 PM
schweinhaus
Mar 22, 2015 10:57 PM
TMI
Aug 10, 2004 02:04 AM
76f1390
21
Feb 11, 2004 12:26 AM
