The radio has a mind of its own, it seems. It started simply turning itself off while traveling. This became more and more frequent. Now all kind of things are happening. If I press the volume **** one time, the radio will play and the tuner, scan, seek will work. If I turn it off and on again, no functions will work. The volume has recently quite working all together.
What should I do? I have the radio out. Do I have a bad connection or what? Please help.
The buttoms on ur HU are probaly broke. there a little switch inside each button that when pressed will release itself. urs are most likely stuck and/or broke. thus causing the radio to act on its own cause the little switch is getting vibrated. i had it happen with a jensen CD player. best bet it to get it replaced.
I had a stock infinity cd head unit that did something like that. Pressing a button was like pulling an arm on a slot machine, never knew what would come up. It got to a point where I just stopped looking, just keep pressing until I got the desired result, didn't matter which button.
Never found the problem, I just yanked it and put something better in there. I suspect it had a burnt resistor or capacitor somewhere surrounding the IC. Its typical for problems like these to surface in the winter, when the heater and radio is on at same time.
