Archived VA Buy/Sell/Trade Ads
#33
Hey Guys found a sweet 66 shortbed for sale today. Turns out it belongs to 65steelstallion. Pics are in his gallery. If interested can email him or 276-358-1096. It's a great truck and he will want a good price (didn't discuss it with him) It's on the road and sounds great with a 352 3 spd.
#34
Trying to sell a bed for 73-79 if you guys know of anybody looking for one.
1979 Ford Truck Bed
Thanks
Kirk
804-307-3983
1979 Ford Truck Bed
Thanks
Kirk
804-307-3983
#36
08 SRW F350 rear blocks w/u-bolts
I have a set of 2008 SRW F350 rear blocks with U-bolts I'd like to sell. According to the instructions I have to get permission from "the Chapter Leader" because I have less than 25 posts...
I don't post a lot so if I missed the obvious details feel free to yell at me.
Who is the Chapter Leader/how do I contact him?
"Take me to your leader..."
Thanks
Thanks
#37
on
1 Post
I've been thinking about either selling my Dont Flame me..85 Dodge Shortbed 4x4.. I have been working on for awhile... It has the 9 3/4" rear with LS..a Dana 44 front..the paint is a 20 footer (black) 318 Auto.. I forget what the tranfer case is..But I can crawl under to find out as the tag is still there..I think it need a new carb...I was just gonna pull the 2bbl off and go 4bbl carb and intake...Interior is very clean for the year..Body is very straight and NO rust..all trim piece's are on the truck..
I would like to trade it for a Ford 4x4 is like condition.. If someone doesnt have a trade here or shows no interest I'll put it on the Dodge site..I thought I would try here first..Because these shortbed 4x4's are becoming collectors, As most of them are banged all to hell or all rusted out..and this is neither... It does have rust on some of the suspension parts ..(springs etc.) and could probably use a new set of springs if someone was going to run it hard off road.. I drove it on the street for about 6 mons..until the carb started screwing up.. But I just have to many projects going on and not enough money to go around..
Thanks for Reading !
~Russ
~Russ
#40
on
1 Post
Any of you Guys out there Have a 360/390
Block laying around your garage somewhere ? a 70's block ? D3TE or D4TE ? I'am in need of one..as the block in my 70 F250 Cracked last winter..My bad..It was ow on anti freeze ! So i need to do another build..any help would be much appreciated !
Also in need of a D9 block for a 460 Stroker project..
Thanks Guys !
~Russ
Thanks Guys !
~Russ
#43
For sale, my beloved 95 F-150 Eddie Bauer, extended cab short bed. The truck has never let me down, EVER! 351w that has some minor head work and fuel system upgrades, Motorsport shorty headers and full header back custom 2 into 1 into 2 race exhaust with header dump. E4OD tranny that has been gone through with Alto clutches, Transgo stage II shift kit in B&M valve body. BW1356 electric shift transfer case, 4.56 gears, solid axle swap to 79 D44 with Yukon chromoly shafts, open diff, Warn hubs. Out back is the 8.8 with the same Yukon 4.56 gears on factory Limited Slip diff with upgraded carbon clucth pack (Motosports part facotry in Cobra Mustangs). 6" Skyjacker custom 1 ton rated coil springs (these things are stiff, for when I had a snow plow to clear my driveway), 4" long add-a-leaf and 2" add-a-leaf kits in stock spring pack to level the truck out. Pro Comp ES9000 shocks at all 4 corners. ProComp Ladder bars (made here in good old Culpeper VA!). The truck sit's on a set of 36" Super Swampers on wagon wheels, and can fit 38" tires no problem (see one of the pic's below!)
Now for the bad news, it needs a new windshield and brakes cleaned up at all 4 corners, which I will do all of that before selling. There is some minor rust through above the rear fenderwells, which is typical on most older trucks. This can easily be fixed with patch panels, or do what I was originally planning to do and cut the fenders for more tire clearance. Other than that, it just needs to be driven. I took it off the road in 2007 after I bought my super duty to be used as a full time mud racer. This truck has held it's own and won many trophys! Here are a few pics and vid of it when I raced it for the last time last year:
And the Last time I raced it:
Sitting next to my buddy's 79 F-250 on 39.5's me on 38.5's:
I have the stock bumpers to go back on to make it road legal as well. Asking $4000 firm. PM me if you want to see it in person.
#44
going through the garage and parts piles I have in an attempt to clean this stuff out
Dana 50 TTB axles and spindles
Dana 50/60 hubs and rotors
Dana 50/60 Ford Lockouts
painted (faded) and prepped 1978 F250 4x4 frame (w/ title, tags)
Rebuilt NP435 & refreshed NP205 (twin stick, needs front yoke, painted)
rear gas tank for 1978 F250 4x4
side mount gas tank for 1978 F250 4x4
rear drive shaft for 1978 F250 4x4
Dana 70u dually axle less drums (4.10)
all steel steering shaft for 1978 F250 4x4
partially ported D3 heads for 460
D9 460 truck block
small block c6 transmission case
BW1345 T-case (rebuildable, has spare parts)
Dana axle seal installer tool
Dana 44 upper balljoint bushing adjuster tool
Sterling 8.8 LS housing and 3.55 gears
Hydro-boost for F-Super Duty. Should be a direct swap for 1980-1997 trucks
Dana 61 rear hubs with new bearings. Should be compatible with different axles, check your part numbers
F600 dual pulley power steering pump, a monster. . .with bracket off a 370
dana 44 hub socket
NEW, in box Eagle SIR 460 rods
Bunch misc small stuff. . .
This stuff has to go, any reasonable offer taken. Come clean out my garage!!!
D9 460 truck block
dana 44 hub socket
