Stereo Issues
Old May 30, 2008 | 11:05 AM
Sarge261's Avatar
Sarge261
Stereo Issues
Hey Guys, I was just wondering if anyone has had this issue. yesterday all worked fine, Today...after the truck sat for a week I decided to get raped and fill it so on the way to the gas station I tuned the stereo on and it worked, so I swiched it to AUX so I could listen to the Sirius and it got stuck. I tried turning the raido on and off nothing.
I pulled over and shut the truck off and the CD worked and so did the AM/FM radio, I switched it back to AUX and it got stuck again. Now nothing works, if I go to CD it will try to initialize the CD but nothing happens. If I try to put it on FM stereo the little headphone symbol comes up and nothing else. The closk does work.
Any Ideas before I call the dealer?
Thanks,
Sarge
OH yeah I did remove the instrument panal fuse box to use power from the battery wire. I am not sure if this has anything to do with that though as I made sure the factory wire was not removed from the stud so it should have not changed anything. The Radio that I installed using that power source works fine, and everything else in the truck works fine also.
Old May 30, 2008 | 05:04 PM
Sarge261's Avatar
Sarge261
Ok,
The only time it will do this..lock up is when I try to use the AUX button. So I havent removed the radio yet to unplug my PIE...Is there a possibility that the PIE is bad causing this issue??
Sarge
Old May 30, 2008 | 06:22 PM
Sarge261's Avatar
Sarge261
Nobody can help ????
