Exhaust Presser Sensor ???
Old May 30, 2008 | 09:20 AM
DIESEL DENNY's Avatar
DIESEL DENNY
1999 F250 7.3, Im getting 6 or 8 MPG in town. I had a scan done and the Exhaust Pressure sensor comes up ???
Any help would be great.
Old May 30, 2008 | 09:28 AM
miller_feed's Avatar
miller_feed
Hook it, I'll pull it.
Look at this and do the cleaning. Then you should be fine. clicky me
You need to make sure none of your boots are leaking. And check for soot on your up pipes.
Old May 30, 2008 | 02:22 PM
bigsteve1969's Avatar
bigsteve1969
i cleaned out but i found a code for the sensor deal just yesterday i dont know if it was tripped before i cleaned it or after i just bought the code reader yesterday and i found it and cleared im gonna check it later this weekend to see if in fact it is the sensor i screwed up ha ha. and no its not no chepo code reader ha ha
Old May 30, 2008 | 02:30 PM
miller_feed
Sounds like you have a good plan going. Let us know what the outcome is.
Good luck.
Old May 30, 2008 | 02:43 PM
superduty4x4's Avatar
superduty4x4
Which code reader did you buy, where, how much?
Old May 30, 2008 | 03:20 PM
bigsteve1969
diablo predator just for the diagnostic capabilities
Old May 30, 2008 | 03:30 PM
ron's power stroke's Avatar
ron's power stroke
could be a bad sensor..if you have a scan tool like AE..or if you can reads volts..then do a health check on the EBPS..here is the readings...
http://www.7point3.com/AETips/Docs/V...th%20Check.pdf
Old May 31, 2008 | 12:12 AM
BrokenBit's Avatar
BrokenBit
I just went through this same thing last week. Matter of fact just put the new sensor in Tues. They have an updated part number, I can get it for ya if you need it, mine ended up costing about $146.oo and another $56 for the tube if you need that (I didn't). When mine was out, it was throwing two codes, changing the sensor fixed both. And so far seems to have brought up the MPG. By the way, thanks again to F350-6 for helping me out on that one I'd prob. still be huntin' the problem if he hadn't jumped in with info.
Old May 31, 2008 | 07:53 AM
bigsteve1969
well when i cleaned mine out my mpg went up too but when i read codes the other day i found those 2 so i dont know if they were threw before i cleaned it out or after so im just gonna let it sit for right now and keep a watch on codes and mpg
Old May 31, 2008 | 08:30 AM
BrokenBit's Avatar
BrokenBit
I'll bet they were thrown BEFORE you cleaned it out. You got any way to reset the DTC's? What are the two codes, you remember? Ours were P0478 & P0470, that's not to say that those are the ONLY codes that a bad sensor can throw, but those are the two I had.
Old May 31, 2008 | 08:32 AM
bigsteve1969
yea i DID clear um so thata way i can watch if they come up
Old May 31, 2008 | 10:00 AM
BrokenBit's Avatar
BrokenBit
gottcha. When ya leavin' for 'Bama? You'll definately know when ya get back. You're gonna love that new 6637!
Old May 31, 2008 | 01:50 PM
DIESEL DENNY
Thanks to everyone, I will clean the tube today & see what happens.
drs041
Jan 28, 2014 04:01 PM
r stene
1983 - 2012 Ranger & B-Series
Jan 26, 2011 10:45 AM
Workin4ALivin
Jun 28, 2009 03:41 PM
ALdieselfan
Jul 14, 2007 05:50 PM
wildjon300ci
Oct 25, 2002 05:58 PM
