<TABLE id=HB_Mail_Container height="100%" cellSpacing=0 cellPadding=0 width="100%" border=0 UNSELECTABLE="on"><TBODY><TR height="100%" UNSELECTABLE="on" width="100%"><TD id=HB_Focus_Element vAlign=top width="100%" background="" height=250 UNSELECTABLE="off">when we bought my truck in May 2007 my dad got his buddy to come over and see it (the guy knows a lot about old cars/trucks). so we were looking at it and we started and he said, "What is that exhaust?" he looked and it was Flowmaster. while he was looking he just glanced and saw the Ford 9" rear. he said, "How much did y'all pay for this truck?" we said, "$2900." he said, "That rear end under there is worth more than what y'all paid for the truck."
I was just wondering if this is true or not? also he said if you want to change the gears from a 3.73 to a 4.10 you'll have the job done in 30 minutes. take the bolts off the housing, pull the gears out, put the new gears in, put the bolts back on.....done. I was just wondering if this stuff is true or not?
oh and how do you tell what kind of rear end it is?
</TD></TR><TR UNSELECTABLE="on" hb_tag="1"><TD style="FONT-SIZE: 1pt" height=1 UNSELECTABLE="on">
</TD></TR></TBODY></TABLE>
I think you can still but used 9" rears for $200 to $300
a good bit more to changing gears than he thinks
how ever a 9" third member can be change in a little over an hr
while the 9" is a fairly decent axle, you can get one for under 500 with some goodies. Anytime I've been around a gear change regardless of axle, it has taken the better part of an afternoon. Don't mean to burst your bubble...and no disrespect, but I wouldn't have that buddy work on anything important on your rig with the statements you relayed in the thread.
I second this statement. The Ford 9" Rear end is a good quality rear end, and the most comon in these trucks.
There are enough Trucks and Vans from the 60's, 70's and 80's alone to keep this rear end low in price for years to come.
Ford 9"
The Only improvement would be a full floating outer axle kit...
My 74 F-100 had a 3:55 limited slip-it worked awesome, and I still have the center section.
Do a search on Ford 9" tons of info, some are 28 spline(cars), some 31, some even had 35 spline from the factory-Early Bronco stuff.
The 70 Boss 429 Mustang had a 9" with I think 4:10 and a locker.
Any performance bow tie car, and even alot of trucks will have a ford 9", or be spending wads on a crappy 12 bolt.
Oh I forgot,
I beat the living hell out of a stock 81 bronco 9" 3:50-1 gears, never even changed the diff oil, turning 33" mudds, and then 35" mudds behind a 69 429, all this in an 88 F-150 chassis.
Hell beat, mud raced, the only survivors were the 429 and the 9"
Center section swap=easy
Gear set up=easy
Enjoy the best built Ford rear axle.
those are very popular with drag raceing...or any raceing to be honest. im not sure what they came in though.
EDIT from the posted site- " The case of course most desirable is the N case, first used on the 427 Galaxies around 64-65 I believe.They are most often found behind the later 428CJ and 429CJ cars.From what I have seen don't expect to find them in 390 or 289 Hipo cars.The N cases went with 31 spline centers and are for rugged duty.And believe it or not, they were also used in some FE equipped Ford 1/2 ton 4X4 pickups! "
and to pull a 9 apart, pull tires, pull hubs, 4 axle bolts on each side, pull axles, 10 bolts in center section, and done....any 9 inch
Reason: edited it
I think the most common gears you're going to find in late 70's ford trucks, is 3.50. It's all I seam to find...
Oh and seriously, it's going to take a while to change gear size in any rearend. The 9 inch is popular because you can have an extra third member on hold incase the one in the car/truck explodes, you can do the swap and get er going again. When changing to a different gear size, take it to a reputable mechanic. If you don't get the clearances right, it won't last long, and you could damage everything in the rear end beyond repair.....I recently exploded a new Auburn Locker, not because of the gear settings, but point is, it wasn't cheap to get another new Auburn gear set, it ruined the ring, pinion and whole locker....
3.50 is pretty standard in 4x4 trucks.
2.75 or 3.00 in 2wd trucks are most common.
Most V8 trucks are 31 spline while 300 I-6 trucks are 28 spline. (at least all that I have checked.)
in 61 years of being around ford pickups I have never saw one come with a 2.75 or 3.00 ratio
the '79 and older lincoln town cars came with 2.7x ratio and 3.00 for towing
I think I have what is a simple enough question...I could find out on my own but don't have the truck with me right now. I have a 77 250 4by with a 400 and came from the factory with a D60 up front and rear and 4.10's, what spline do you figure it has? I can't believe I've never checked. I figure 31 spline is probably about as good as it gets, ford probably didn't do 35 from the factory right?
Interesting...never knew that. What about a 77 that was built in December of 76 (still in the hi boy era)?
I wondered the very same thing when i read your earlier post, most highboy's came with the HD44 up front but since yours was ordered with a D60 you may very well have a 35 spline count axle, if it's a high pinion D60 i can almost guarantee you it's 35 spline, if it's a low pinion D60 then most likely it's a 30 spline.
