lift block question
Old May 28, 2008 | 09:15 PM
camccardell's Avatar
camccardell
lift block question
I would like to get a few more inched out of my truck and would like to purchase some lift blocks. However there are allready 2 inch factory blocks on the rear. Can I buy some universal ones and use them with the factory block or do I have to pitch the factory ones? I ask because I was looking to get 2-3 more inches, and I was wondering if they needed to be tapered for pinion angle. I have also heard that you aren't supposed to use 2 block at once, but I sweat I've seen trucks set up like that.
Thanks
Chris
Old May 29, 2008 | 12:50 AM
Dre82s's Avatar
Dre82s
you can put two block no problem, they just gotta connect to each other; however, you are not allowed to put block on the front leaf springs that is illegal, dot will shaft you for it.
Old May 29, 2008 | 08:03 AM
Conanski's Avatar
Conanski
No.. don't stack blocks if you have the choice, install a taller block to replace the existing one. And you should also install traction bars because the axle is gonna wrap even worse than it does stock. It also wouldn't hurt to use a tapered block, it doesn't take much or an angle on the U-joint to produce a major vibration problem.
Old May 31, 2008 | 09:24 PM
camccardell
I am getting both sides again!!! :P
Is the stock block 2 inches tall?
If so, I guess I would need a 5 in block.
Any recomendations on good traction bars?
Old May 31, 2008 | 10:02 PM
Conanski's Avatar
Conanski
Rocky Mountain Suspension Products, traction bars
stephen.south
Nov 8, 2010 05:14 PM
TwelveAlpha
Offroad & 4x4
Nov 8, 2006 07:12 PM
muddyford75
May 17, 2004 11:40 PM
chris112lee
Jan 1, 2002 02:53 AM
