white residue
Old May 28, 2008 | 05:11 PM
paddler65's Avatar
paddler65
white residue
open hood to look for PCM and FICM and discovered white residue on battery, filter cover, fuse cover and anti freeze bottle. drivers side sprayed good. have added antifreeze two times in past yr. antifreeze level at the bottom of bottle. bottle cap was on ok.
what is going on?
what do i do next?
thanks
05 f-350 psd cc 4x4 drw auto
Old May 28, 2008 | 05:29 PM
brickie's Avatar
brickie
The coolant should be just under the min line.If it is blowing coolant lower than min you have pressure in the system caused most likely by head gasket failure or a blocked oil cooler causing boiling coolant in the EGR cooler.
Old May 28, 2008 | 05:52 PM
paddler65's Avatar
paddler65
will i see any evidence of blown head gasket on oil dip stick?
05 f-350 psd cc drw 4x4 auto
Old May 28, 2008 | 09:48 PM
brickie's Avatar
brickie
No the dip stick shows signs of neglect.
Old May 28, 2008 | 11:24 PM
paddler65's Avatar
paddler65
i will go to dealer tomorrow for white residue.
had a bed plate leak repaired in march.
bottom of bell housing is dry.
thanks
Old May 29, 2008 | 10:43 AM
paddler65's Avatar
paddler65
went ot ford dealer and they will look at cooler first because that is the cheapest route.
gene 05 f-350 4x4 cc drw auto
