Changing axle ratio
It is a 4wd but I've only used 4wd twice since I bought it a year ago so its not like I need the gears I have right now to go off roading or towing or anything like that.
IF you change the rear gears, you have to change the front or if you put the truck in 4wd, the transfer case will bind and you'll hear one big,expensive bang!
Changing gears is nothing for a avearge DIY mechanic. I know how, seen how, understand how, but still didn't feel comfortable enough to do it myself, so I brought it to a professional.
You're looking at about $600 and axle for parts(ring and pinion, master install kit) + tax, and labor, and that's if you don't install any traction aids(LS, Locker).
You'd need something around 3.00 gears to get that low of an RPM at hwy speeds, but the acceleration is going to suck!
You will get terrable gas mileage trying to accelerate, b/c the engine will be straining to get the heavy truck moving(b/c it doesn't have enough gear).
Depending on your tire size, you might have enough room to install larger tires to affectively lower(numatically) your gear ratio, which would be easier/cheaper than changing gears front and rear and lower your hwy RPMs at the same time.
The tires are 9.5-16.5.
Right now first gear is so low that I always use 2nd gear to start out on even on hills.
I just put the axle back together for my Camaro so this is something I can do myself.
The granny low first gear will help get the truck moving if you have 3.00 gears, but after that, your truck will be pretty slugish.
Somewhere around 3.25 would be better for hwy driving, but if you tow or do a lot of in town driving, it's not worth it.
Timken bearings are real good, but a master install kit from yukon or somewhere else would be good enough.
It'll be about $150 for each ring and pinion and about $90 each master install kit plus gear oil and new gaskets or RTV
$500 in parts alone plus tax or shipping.
And that's assuming you set everything up right and not start chipping teeth off the ring gear the first time you use it, then needed to buy everything all over again and have a professional do it.
MPH X Gear ratio X 336 divided by Overall Tire height in inches = RPM
Examples :
60 X 3.50 x 336 / 31 inch tire = 2276 RPM
60 X 4.11 x 336/ 31 inch tire = 2672 RPM
