Converting to Propane ... Worth another look ??
Old May 27, 2008 | 09:59 PM
OldFordRacer's Avatar
OldFordRacer
With Propane at about 1/2 the price of gasoline, I am thinking seriously of converting my '68 F250 4x4 w/410 engine ...
I am looking for suggestions/opinions, pro and con, on converting to full-time propane power for my gas-guzzlin' 410 ...
My Son and I recently completed a full restoration of the truck and now I WANT TO DRIVE IT, DAMN IT !!! ... However, at 10 mpg fuel consumption, that is out of the question ...
I would greatly appreciate any serious suggestions and opinions ...
Old May 30, 2008 | 04:02 PM
gasman6674's Avatar
gasman6674
If you have a conveient source for fuel and dont mind spending another couple of grand on it go for it. If you set it up correctly you shouldnt notice any power loss, minimal if any MPG loss, and you will be able to extend your service life on oil, plugs etc. I would recommend dual fuel so you can run both fuels for greater range. Check with your local LP Dealer / clean air board there may be grants to subsidise the equipment.
If you dont mind a big tank in the bed you will be able to carry up to 100 gals of fuel
If you have more questions drop me an e-mail also you might want to look at the Alt Fuel Fourm
regards
Old Jun 8, 2008 | 09:49 AM
blue beast's Avatar
blue beast
Gasoline Gallon Equivalents - GGE - What is a Gallon Equivalent
Old Jun 8, 2008 | 12:54 PM
projectSHO89's Avatar
projectSHO89
Expect around 74% of gasoline's efficiency. With this past week's average price per gallon for retail residential propane of $2.31 (Missouri average), your gasoline equivalent cost is $3.12/gallon net before taxes.
This past week's national average for unleaded fuel was $3.97/gallon (Missouri's was $3.79) before Fridays huge gap-up in crude. Since both propane and gasoline's prices are closely tied to crude, you can expect a jump in both really, really soon (gas already jumped 14 cents yesterday).
Not much difference in the costs to amortize the cost of the conversion unless you do a LOT of miles with the old gas-hog.
Steve
Old Jul 5, 2008 | 07:02 AM
kaboom10's Avatar
kaboom10
When we tried it at Holley the best part was the cold starting here during the Michigan winters. It is a vapor and much easier to ignite at cold temps. Gasoline has to be vaporized first. If you're going to spend that much money I would suggest going to an aftermarket fuel injection system. Just stay away from CNG unless the valve recession problem has been over come.
Old Jul 20, 2008 | 12:06 PM
magusjinx's Avatar
magusjinx
Ditto about the fuel energy comparison ... Your mileage will probably decrease by about 10-15% as well as your appearent power curve ...
jonnybronco
Bio-diesel, Propane & Alternative Diesel Engine Fuels
Mar 6, 2014 11:27 PM
ddaa99
Jun 18, 2006 09:56 AM
NickFordMan
May 19, 2006 07:03 AM
racer956
Mar 21, 2005 11:22 PM
bremen242
Alternative Fuels, Hybrids & Mileage
15
Dec 1, 2004 06:40 AM
