scrapping....
Old May 27, 2008 | 06:35 PM
highrisk's Avatar
highrisk
scrapping....
I need to take take the cab off of a 88 F-350 4x4 CC that I am dismantling for parts....I know the steering column will need to be disc and both shifter and floor shifter will have to be disc too......assorted wiring etc....question is how many bolts are there holding it to the frame?...4? 6?...want to pull the cab and fenders and nose off to pull the motor tranny and trans together.....as easily as possible with limited ground work.....once the eng/tranny/trans....is clear ......torch the u-bolts on the rear and the spring perches on the front and ....DONE.....any thoughts?
Old May 27, 2008 | 08:50 PM
frederic's Avatar
frederic
The radiator core is mounted with two bolts, and the cab itself has four bolts, for a total of six.
