water pump
Old May 27, 2008 | 11:41 AM
indebt's Avatar
indebt
water pump
So I was goona put my ATS housing in and while under my truck to drain the ccv catch I notice I have a leak. I am gonna get the ebay water pump and the 203 stat, do I need to get the billet housing or is the "reg" one fine. I am also gonna add a coolant filter so I dont have to do it again EVER. the leak looks like is coming from all around the pump. I never noticed it cuz it was falling on the lower hose and never hitting the ground.
Old May 27, 2008 | 11:43 AM
papadelogan's Avatar
papadelogan
Snowboard season cometh..
Get the billet housing - the OEM one is a "single-use" item... i.e. JUNK. Billet will last about as long as your truck!! Don't forget to get new bolts too - they're 6mm IIRC and you should be able to get some from Home Depot (maybe) - find an IH dealer though for them otherwise. Ford wanted $3 EACH, but when I called the IH dealer, they said "if you buy all 7 we'll sell them to you for $3 TOTAL".... hmmmm...OK!!
