Hissing noise
Old May 27, 2008 | 09:18 AM
Super350's Avatar
Super350
Hissing noise
I have a 2005 Nav. For the last couple of months I have been having a hissing air sound comming out of the dashboard ?. The only thing that makes it go away is pressing the brake. ?????
Old May 29, 2008 | 04:53 PM
hovey30's Avatar
hovey30
I have the same issue with my 2000 Exp. I am looking into it and I will post a reply if and when I get it figured out.
Old May 29, 2008 | 05:26 PM
alloro's Avatar
alloro
Two things come to mind. One, and I'm not sure if this applies to your models or not, but some cruise control systems have a vacuum switch tied to the brake pedal down under the dash. This aids in quickly stopping the cruise control vacuum actuator from holding the throttle open. Two, there is a rupture in the internal diaphragm of the power brake booster. You could disconnect and plug the vacuum hose from the booster and see if the hiss goes away.
Old Jun 3, 2008 | 10:59 AM
Frat-man-du's Avatar
Frat-man-du
If equipped with an emergency brake vac release then it could be that as well, but suspect Alloro is right on the the cruise control actuator.
It should be easy to spot once you wiggle you way up under the dash to look and listen for it, if it is not the power booster.
Pridnjoy
Sep 7, 2013 08:50 PM
dpurcell
Sep 14, 2011 01:15 AM
robs01f250
22
Nov 17, 2010 12:27 PM
serussell
Mar 4, 2007 09:19 AM
irazu
1983 - 2012 Ranger & B-Series
Jan 5, 2004 08:50 PM
