Sponsored by: Auxito
Air Suspension
Old May 26, 2008 | 08:53 PM
Lavern's Avatar
Lavern
Air Suspension
My 98 F-150 4.2L 4x4 Reg. Cab 5 speed I noticed beside the fuel shut off on the pass. side has Air Suspension written beside it. I know my truck doesnt have air ride but does this mean I am able to install it? Thanks.
Old May 26, 2008 | 09:12 PM
triton_2002's Avatar
triton_2002
I'm sure you could swap in a Navigator or Expy set up, it you got enough time and money
Old May 27, 2008 | 04:26 PM
Lavern's Avatar
Lavern
If I did that it would mean I could adjust the softness and stiffness of my suspension right? Thanks for the reply.
Old May 27, 2008 | 11:17 PM
malbojah's Avatar
malbojah
I have a set of Air-Ride helper springs on my 98 XLT 4.2. I can load the bed full, pump up the bags to about 60 psi (max 100) and not notice and sag on the leaf springs. I do notice the extra weight when leaving from a stoplight or coming to a stop.
Old May 28, 2008 | 06:50 PM
screwy's Avatar
screwy
It’s there because the same panel is used in the expy, which did have the option.
Old May 28, 2008 | 07:43 PM
Lavern's Avatar
Lavern
Thanks for the info...I haul a heavy load pretty often so maybe these will be worth the investment if they work as good as malbojah says they do....thanks again
Old May 28, 2008 | 09:42 PM
malbojah's Avatar
malbojah
Sorry, it was Air-LIFT, not Air-Ride
