Bad Voltage Regulator
Old May 26, 2008 | 07:52 PM
STACK86's Avatar
STACK86
OK, I have determined that the Voltage Regulator is bad and need to replace. Short of pulling the alternator which is going to be a pain, is there a way to determine if the VR is internal or external. I can not tell from looking down on the unit. Also, do I need to pull the smog pump to get the Alternator out?
Thanks,
STACK
Old May 26, 2008 | 07:56 PM
ReadOrDie_DW's Avatar
ReadOrDie_DW
Isn't the Voltage Regulator on the passengar side fender wall? What year,engine, model is your truck?
Old May 26, 2008 | 08:54 PM
STACK86's Avatar
STACK86
Bad Voltage Regualtor
Sorry, 86' F150 with 302. The Starter Solenoid is on the Fender but I do not see the VR.
Stack
Old May 26, 2008 | 08:58 PM
ri_truck_guy's Avatar
ri_truck_guy
With an 86 302 you should have a 2G alternator with an internal regulator. Get under the truck and look up at the alternator. You'll see a larger rectangular plug with three wires, and a smaller D shaped plug, also with three wires. The smaller D shaped plug is the voltage regulator.
Old May 26, 2008 | 09:24 PM
STACK86's Avatar
STACK86
Alternator Replacement
If the VR is internal, can it be replaced without changing the Alternator?
All help is appreciated.
STACK
Old May 26, 2008 | 09:35 PM
ri_truck_guy
Yes...you can put a new voltage regulator on your existing alternator. it's held on the back of the alternator with 4 torx head screws. You will most likely have to drop the alternator to get at them.
Old May 27, 2008 | 03:39 AM
srercrcr's Avatar
srercrcr
I'm curious how you diagnosed a bad VR.
Old May 27, 2008 | 06:00 AM
STACK86's Avatar
STACK86
Using the basic check of battery voltage with truck running. The voltage at the battery was over 16.3 volts DC. The normal range should be between 14-15 volts. If high then the VR is usually bad.
Old May 27, 2008 | 10:40 AM
JimsRebel's Avatar
JimsRebel
Also check to see if the 16.3 volts dropped when you turn on the head lights, it would indicate it is not regulating the voltage. Some cheap volt meters are not that accurate.
danerisfree
1978 - 1996 Big Bronco
Apr 8, 2015 06:42 PM
sacseven
Dec 15, 2014 06:34 AM
ZombieSlayer
Feb 15, 2014 11:34 PM
wallycrabtree
Oct 13, 2009 09:36 AM
