Sponsored by: Real Truck
Front drive line problem
Old May 26, 2008 | 04:46 PM
eddiedebb's Avatar
eddiedebb
I have a 2003 4x4 and i thought i just had a bad u-joint in the front driveline at the t-case. Took out the drive shaft and all the ujoints are good but i had a lot of slop rough movement in the double u-joint. Upon disasembly, I discovered the entire center ball and socket is trashed (first time I have ever see one of these). Are these repairable or do i need to buy the intire driveline asembly? I have only owned the truck for a month so I am still learning about it.
Old May 27, 2008 | 12:39 AM
ReAX's Avatar
ReAX
I have a double u-joint in the front of mine, I believe. What it sounds like you have is a constant velocity joint like front wheel drive cars. I believe you only have two choices, if it's u-joints replace the u-joints, or if it's a CV joint, you will have to replace the CV as a unit.
Old May 27, 2008 | 07:33 AM
eddiedebb's Avatar
eddiedebb
It is a combination of the two.There is a double u-joint set up and in the middle of the double joint(inbetween them) there is a scoket, ball and boot. You can not see the inner ball until you remove the shaft from the truck. I was suprised. My haynes book only mentions this joint briefly by stating: when removing the u-joint, pay close attetion to the ball and spring and the order they come out.: lol...thanks
Old May 28, 2008 | 12:24 AM
ReAX's Avatar
ReAX
If it has serviceable u-joints, try just replacing them. It sounds like the center ball is reuseable.
Old May 28, 2008 | 11:30 AM
eddiedebb's Avatar
eddiedebb
The ujoints are in good shape. Problem is the socket and pin the ball setup goes in is trashed. I dont have much choice except buy another drive line.
Old May 28, 2008 | 11:45 AM
krewat's Avatar
krewat
FTE Leadership Emeritus
There should be a single u-joint on one end, and a double u-joint (CV joint) on the other end.
Are you talking about the "slip yoke" - which is where the driveshaft can extend and retract with the up-and-down motion of the front axle?
If it's acting like a "ball and socket", it's trashed - it should just extend and retract.
