amp for stereo
Old May 26, 2008 | 02:05 PM
cps's Avatar
cps
amp for stereo
I still have the factory sound system and i would like to know if it is possible to plug in an after market 4 channel amp to the stock system with out to much wiring issues.I like the versatility have having the CD/TAPE player and do not want to remove it but i need more volume.Can anyboby help? Roy
Old May 26, 2008 | 02:44 PM
PowerstrokeJunkie's Avatar
PowerstrokeJunkie
Volume, or bass? I dont think it's possible to hook up an amplifier to a stock head unit, there are NO pre-amp outputs, no hookups for RCA's.
Old May 26, 2008 | 04:51 PM
rustydailey's Avatar
rustydailey
You can get one of these, they have speaker level inputs.
Amplifiers at Crutchfield.com
Or you can buy a high to low level converter.
Compare Prices on Scosche Slc4 Speaker High Level Converter
Just a few examples.
Either way you go you are going to have to splice into the factory harness.
Old May 26, 2008 | 05:03 PM
nlemerise's Avatar
nlemerise
Great job Rusty...rep given. If you have this knowledge can I ask a question or two? What would be the best direction to go if a person wanted to add just a line level amp (as in your first link), compared to adding a converter and an external amplifier? What are the disadvantages of each approach to solving the problem?
Old May 26, 2008 | 05:39 PM
rustydailey
Well it's been a while but I will give it a shot.
If you went with the converter you could run any amplifier you wanted, ie. you would have a greater selection. But you could also have a chance to introduce noise into the signal, but since a PSD doesn't have an ignition, and the better construction of electronics it would probably not happen. You also only have to run one cable to the amp.
If I were going to do it, I would use the converter, run a set of RCA cables to the amp and then run a set of speaker wires back to the factory harness. That would be the easiest way for me to do it.
