76 Highboy steering conversion HELP
Old May 26, 2008 | 10:29 AM
wrenchguy's Avatar
wrenchguy
Hi, I'm trying my hand at doing a conversion and just realized I have the box that goes on the outside of the frame. Can anyone give me pointers or pics please ? The only thing that looks tough is the clearance for crossover between the spring. I would rather use the other box and beef the frame but it's my step dads rig and I'm putting out the monies myself. Any help will be appreciated.
Old May 26, 2008 | 10:54 AM
armstrongfordtrucks's Avatar
armstrongfordtrucks
check out the pic's in my gallery.
good luck
ARMSTRONGFORDTRUCKS
Old May 26, 2008 | 11:35 AM
75F350's Avatar
75F350
Welcome to the site;
Many of us have performed this conversion, and a few of us have done it a little differently.
Take a cruise through my photobucket to see how i mounted my junk.
Image of saginaw power steering conversion - Photobucket - Video and Image Hosting
Old May 26, 2008 | 02:21 PM
wrenchguy's Avatar
wrenchguy
[/IMG]
My real problem would be to figure out what pitman arm and draglink to use in this situation. If all else fails I'll switch gear boxes. As you can see no clearance here. about 37" to the original spot the steering assist cylinder had attached to.
Old May 28, 2008 | 06:56 PM
Action4478's Avatar
Action4478
I used a gear box from a chevy 3/4 ton ,,Mounted on the outside of the frame rail,,, used a chev tie rod end on one end & the ford on the other ,,a 70 cutlass rag joint & lower column shaft ...Ford PS pump lines hooked right to the new gear box ,,, it steers like a car ,,even with the plow on it...
Pic.... here ....
Vin Man
17
Nov 25, 2012 09:59 AM
dilyb
Feb 12, 2009 08:30 AM
seaves46
May 14, 2005 08:11 AM
dieingford
Paint & Bodywork
Apr 7, 2004 08:38 PM
mwilson
Dec 22, 2003 02:31 PM
