Oil Leak
Old May 26, 2008 | 10:13 AM
bkcowboss's Avatar
bkcowboss
Oil Leak
I have a significant oil leak, 5 quarts in 2000 miles. From the bottom of the truck , I look up and it appears to be dry at the top of the bell housing, the oil looks like it is coming out of the vent on the dust cover of the bell housing. I was suspecting the turbo orings but those look dry. Is the issue likely the rear main seal? If so can I pull the dust cover and verify by looking at it? Any input would be great.
thanks
edit: it is the 03 Excursion that has the issue, see my Sig. The whole back of the truck is covered with oil
Old May 26, 2008 | 11:13 AM
F350-6's Avatar
F350-6
Check the valley on top of the motor to be sure it's not full of oil.
