IP timing problem
Old May 25, 2008 | 10:49 PM
sbin's Avatar
sbin
IP timing problem
Bought a 93 F350 the previous owner said something about turning up the injector pump for better performance.
After driving recently with a load I have some questions about how to correct what was done.
The truck drives alright empty but lacks any low end torque.When pulling a large empty machine trailer last weekend the truck had to be down shifted to deal with even minor uphill grades and poured black smoke when given some petal but did not pull.The temperature gauge raised almost as fast as the speedo.Keeping the rpm around 2500 provided the best power.
What should I do?
It seems like the pump might be timed incorrectly and providing too much fuel.Does this sound like too much advance or retard?
Any advice would be most appreciated.
Old May 25, 2008 | 11:02 PM
PLC7.3's Avatar
PLC7.3
Sounds similar to too advanced........BUT if the IP was turned way up that may be part of the problem...... Is there a pyrometer installed?
Ziggster's page has info on the pump turn up...... possibly turn it down a few flats.
Where are the alignment (timing) lines on the IP and timing cover in relation to each other.... does the engine rattle really bad all the time.
Old May 26, 2008 | 12:10 AM
Dave Sponaugle's Avatar
Dave Sponaugle
Sounds like the fuel screw is maxed out or the air filter is dirty.
Old May 26, 2008 | 10:46 AM
sbin's Avatar
sbin
The air filter is new so adjusting the fuel screw and checking the IP timing marks sound like a good place to start.How can youj tell if the fuel screw has been leaned out too much?
The plan is to replace the IP and injectors but that has to wait until daughters university bill gets paid down some.She is going to Marietta down by Dave's part of the world.
Old May 26, 2008 | 07:34 PM
Dave Sponaugle
No such thing as leaned out on a diesel.
Old May 27, 2008 | 02:04 AM
RLDSL's Avatar
RLDSL
just try turning it down one flat at a time till it gets where you like it. To keep from going insane trying to find the screw in the little window, I've found it easiest to just pop those two bolts off and pop the front inspection plate off to see where the position of the pin is ( see ziggs article ) and I use that anaerobic gasket sealer when putting the plate back on. It cleans up easily and sets fairly quick.
